[cgal-discuss] Info insert with pair iterators into Delaunay 3D triangulation example error
- To:
- Subject: [cgal-discuss] Info insert with pair iterators into Delaunay 3D triangulation example error
- Date: Thu, 30 Oct 2014 20:21:58 -0700
Hello all,
I cannot get the example to compile:
Using this:
(in my project repo as https://github.com/acgetchell/CDT-plusplus/blob/master/src/info_insert_with_pair_iterator.cpp )
Produces:
The first few lines of which I reproduce below:
┌─[adam][Hapkido][±][master ✓][~/CDT-plusplus]
└─▪ ./build.sh
-- The C compiler identification is AppleClang 6.0.0.6000054
-- The CXX compiler identification is AppleClang 6.0.0.6000054
-- Check for working C compiler: /usr/bin/cc
-- Check for working C compiler: /usr/bin/cc -- works
-- Detecting C compiler ABI info
-- Detecting C compiler ABI info - done
-- Check for working CXX compiler: /usr/bin/c++
-- Check for working CXX compiler: /usr/bin/c++ -- works
-- Detecting CXX compiler ABI info
-- Detecting CXX compiler ABI info - done
-- Build type: Release
-- USING CXXFLAGS = ' -O3 -DNDEBUG'
-- USING EXEFLAGS = ' -Wl,-dylib_file,/System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGL.dylib:/System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGL.dylib '
-- Targetting Unix Makefiles
-- Using /usr/bin/c++ compiler.
-- DARWIN_VERSION=14
-- Mac Leopard detected
-- Requested component: Core
-- Requested component: MPFR
-- Requested component: GMP
-- Found Eigen3: /usr/local/include/eigen3 (found suitable version "3.2.2", minimum required is "3.1.0")
-- Configuring done
-- Generating done
-- Build files have been written to: /Users/adam/CDT-plusplus/build
Scanning dependencies of target cdt
[ 12%] Building CXX object CMakeFiles/cdt.dir/src/cdt.cpp.o
Linking CXX executable cdt
[ 12%] Built target cdt
Scanning dependencies of target info_insert_with_pair_iterator
[ 25%] Building CXX object CMakeFiles/info_insert_with_pair_iterator.dir/src/info_insert_with_pair_iterator.cpp.o
In file included from /Users/adam/CDT-plusplus/src/info_insert_with_pair_iterator.cpp:1:
In file included from /usr/local/include/CGAL/Exact_predicates_inexact_constructions_kernel.h:28:
In file included from /usr/local/include/CGAL/Simple_cartesian.h:28:
In file included from /usr/local/include/CGAL/Cartesian/Cartesian_base.h:28:
In file included from /usr/local/include/CGAL/basic.h:29:
In file included from /usr/local/include/CGAL/config.h:55:
In file included from /usr/local/include/boost/config.hpp:44:
In file included from /usr/local/include/boost/config/select_stdlib_config.hpp:37:
In file included from /usr/local/include/boost/config/no_tr1/utility.hpp:21:
In file included from /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/../include/c++/v1/utility:157:
/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/../include/c++/v1/__tuple:228:60: error:
no member named 'value' in 'std::__1::is_convertible<const
CGAL::Point_3<CGAL::Epick> &, CGAL::Point_3<CGAL::Epick> >'
is_convertible<_Tp0, _Up0>::value &&
Adam Getchell
about.me/adamgetchell
- [cgal-discuss] Info insert with pair iterators into Delaunay 3D triangulation example error, Adam Getchell, 10/31/2014
