- To:
- Subject: Re: [cgal-discuss] Inserting random spheres into Delaunay triangulations
- Date: Wed, 29 Oct 2014 16:22:15 -0700
Sebastien,
Thank you, that worked.
Adam Getchell
about.me/adamgetchell
> On Oct 29, 2014, at 12:15 AM, Sebastien Loriot (GeometryFactory)
> wrote:
> Scd is CGAL::Simple_cartesian<double> and the traits provided to the
> triangulation is EPIC. The point types are different so you cannot
> insert them. Replace Scd::Point_3 by K::Point_3 and it will work.
> Sebastien.
> On 10/29/2014 05:24 AM, Adam Getchell wrote:
>> Hello all,
>> I’m created nested spheres of random points (where each sphere of
>> differing radius represents a timeslice) that I’d like to triangulate.
>> I’m very close, but I’m not quite there:
>> inline void make_S3_triangulation(Delaunay* D3, int simplices, int
>> timeslices) {
>> // std::cout << "make_S3_triangulation() called " << std::endl;
>> const int points = simplices * 4;
>> const double radius = 1;
>> const bool message = false;
>> std::vector<Scd::Point_3> vertices;
>> make_3_sphere(&vertices, points, radius, message);
>> //D3->insert(vertices.begin(), vertices.end());
>> for (auto point : *vertices)
>> D3->insert(point);
>> Gives me this compiler error:
>> *Scanning dependencies of target cdt*
>> [ 14%] Building CXX object CMakeFiles/cdt.dir/src/cdt.cpp.o
>> In file included from /Users/adam/CDT-plusplus/src/cdt.cpp:24:
>> */Users/adam/CDT-plusplus/src/S3Triangulation.h:49:21: **error:
>> **indirection*
>> * requires pointer operand ('std::vector<Scd::Point_3>' invalid)*
>> 1 error generated.
>> make[2]: *** [CMakeFiles/cdt.dir/src/cdt.cpp.o] Error 1
>> make[1]: *** [CMakeFiles/cdt.dir/all] Error 2
>> make: *** [all] Error 2
>> The relevant code is:
>> https://github.com/acgetchell/CDT-plusplus/blob/master/unittests/Triangulated2SphereTest.cpp
>> Which calls:
>> https://github.com/acgetchell/CDT-plusplus/blob/master/src/S3Triangulation.h
>> (offending lines commented out so everything else compiles)
>> Which calls:
>> https://github.com/acgetchell/CDT-plusplus/blob/master/src/Sphere_3.h
>> Pointers (or iterators) welcome!
>> Adam Getchell
>> about.me/adamgetchell <http://about.me/adamgetchell>
> You are currently subscribed to cgal-discuss.
> To unsubscribe or access the archives, go to
> https://sympa.inria.fr/sympa/info/cgal-discuss
- [cgal-discuss] Inserting random spheres into Delaunay triangulations, Adam Getchell, 10/29/2014
- Re: [cgal-discuss] Inserting random spheres into Delaunay triangulations, Sebastien Loriot (GeometryFactory), 10/29/2014
- Re: [cgal-discuss] Inserting random spheres into Delaunay triangulations, Adam Getchell, 10/30/2014
