cgal-discuss - [cgal-discuss] Restore valid Delaunay triangulation after tds().delete_cell(cit) is used
  • To:
  • Subject: [cgal-discuss] Restore valid Delaunay triangulation after tds().delete_cell(cit) is used
  • Date: Tue, 11 Nov 2014 13:22:44 -0800
Hello all,
I am storing some timeslice data in each vertex of a 3D Delaunay
triangulation, and then ensuring that each cell is correctly foliated (i.e.
maximum timeslice - minimum timeslice == 1).
For those cells that fail this criteria, I delete them using
tds().delete_cell(cit).
https://github.com/acgetchell/CDT-plusplus/blob/master/src/S3Triangulation.h
However, this produces an invalid triangulation.
How do I fix these holes?
As an alternative approach, instead of using delete_cell() defined on the
triangulation data structure, I can iterate over the vertices in each cell
and individually remove them using the remove(cit->vertex(i)) function
defined on the Delaunay triangulation. This results in valid triangulations
for large number of cells, but also removed all vertices for small number of
cells (such as two tetrahedrons), and also doesn’t seem to delete all
invalidly foliated triangulations.
Is this generally a better approach, or is there an easy way to fix up the
missing cells?
Thanks for any advice.
Adam Getchell
about.me/adamgetchell
