Re: [cgal-discuss] Restore valid Delaunay triangulation after tds().delete_cell(cit) is used
- To:
- Subject: Re: [cgal-discuss] Restore valid Delaunay triangulation after tds().delete_cell(cit) is used
- Date: Wed, 12 Nov 2014 09:40:10 -0800
> On Nov 11, 2014, at 2:02 PM, Marc Glisse
> wrote:
> On Tue, 11 Nov 2014, Adam Getchell wrote:
>> I am storing some timeslice data in each vertex of a 3D Delaunay
>> triangulation, and then ensuring that each cell is correctly foliated
>> (i.e. maximum timeslice - minimum timeslice == 1).
>> For those cells that fail this criteria, I delete them using
>> tds().delete_cell(cit).
>> https://github.com/acgetchell/CDT-plusplus/blob/master/src/S3Triangulation.h
>> However, this produces an invalid triangulation.
>> How do I fix these holes?
> What do you mean? The Delaunay triangulation is uniquely determined by the
> points. If you remove a cell, "fixing" the triangulation means adding that
> cell back...
> Or maybe what you want is not a triangulation?
Well, I definitely want a triangulation, since that corresponds to a
simplicial manifold which is necessary for the physics in the model.
Okay, I’ll look at deleting points, which seems to allow for a “rebalance”
which maintains the Delaunay triangulation.
Thanks Marc!
> Marc Glisse
> You are currently subscribed to cgal-discuss.
> To unsubscribe or access the archives, go to
> https://sympa.inria.fr/sympa/info/cgal-discuss
Adam Getchell
about.me/adamgetchell
- [cgal-discuss] Restore valid Delaunay triangulation after tds().delete_cell(cit) is used, Adam Getchell, 11/11/2014
- Re: [cgal-discuss] Restore valid Delaunay triangulation after tds().delete_cell(cit) is used, Marc Glisse, 11/11/2014
- Re: [cgal-discuss] Restore valid Delaunay triangulation after tds().delete_cell(cit) is used, Adam Getchell, 11/12/2014
