- To:
- Cc: Julian Panetta <>
- Subject: Re: [cgal-discuss] Bugs in AABBTree
- Date: Wed, 12 Nov 2014 08:36:51 +0100
This is most probably a floating point computation issue.
Also have a look here:
http://www.cgal.org/FAQ.html#inexact_NT
Sebastien.
On 11/10/2014 10:04 PM, Qingnan Zhou wrote:
Dear all,
There seems to be a bug that causes CGAL::AABBTree to produce wrong
results. The following code would illustrate the problem:
It basically compute the center of each face and query the distance
between the centroid and the mesh. Ideally, the query should always
return 0 as the distance and the source face index, otherwise the code
will print out the face that causes the failure.
typedef CGAL::Cartesian<Real> K;
typedef K::Point_3 CGALPoint;
typedef K::Triangle_3 CGALTriangle;
typedef CGAL::AABB_tree<AABB_triangle_traits> AABBTree;
typedef AABBTree::Point_and_primitive_id Point_and_primitive_id;
AABBTree *coarseTrianglesTree =
new AABBTree(triangles.begin(), triangles.end());
coarseTrianglesTree->accelerate_distance_queries();
size_t count = 0;
for (auto itr : triangles) {
CGALPoint c = CGAL::ORIGIN + ((
(itr[0] - CGAL::ORIGIN) +
(itr[1] - CGAL::ORIGIN) +
(itr[2] - CGAL::ORIGIN)) / 3.0);
Point_and_primitive_id pp =
coarseTrianglesTree->closest_point_and_primitive(c);
size_t face_index = pp.second - triangles.begin();
double distance = coarseTrianglesTree->squared_distance(c);
if (distance > 1e-3) {
std::cout << count << std::endl;
std::cout << "distance = " << distance << std::endl;
std::cout << "face idx = " << face_index << std::endl;
count ++;
When running this test on meshes such as "suzanne.obj
<https://www.dropbox.com/s/j1xj8nfy68xpdqc/suzanne_tri.obj?dl=0>", the
query fails on quite a few faces (the query finds the incorrect face
index and gets a distance ~= 10^-3).
We are able to reproduce the error with CGAL 4.4 and CGAL 4.5 on
Redhat Enterprise Linux server with the following setting:
gcc 4.8.2, gmp 6.0.0 (also tried 4.3.1), mpfr 3.1.2, boost 1.53
CentOS 6.3 with the following setting:
gcc 4.8.2, gmp 6.0.0a, mpfr 3.1.2, boost 1.55.0
Strangely it works on the version compiled by macports. We have tested
CGAL 4.3 and 4.4 on mac.
best,
James
- [cgal-discuss] Bugs in AABBTree, Qingnan Zhou, 11/10/2014
- Re: [cgal-discuss] Bugs in AABBTree, Sebastien Loriot (GeometryFactory), 11/12/2014
- Re: [cgal-discuss] Bugs in AABBTree, Qingnan Zhou, 11/12/2014
- Re: [cgal-discuss] Bugs in AABBTree, Laurent Rineau (CGAL/GeometryFactory), 11/12/2014
- Re: [cgal-discuss] Bugs in AABBTree, Julian Panetta, 11/12/2014
- Re: [cgal-discuss] Bugs in AABBTree, Sebastien Loriot (GeometryFactory), 11/13/2014
