cgal-discuss - Re: [cgal-discuss] Bugs in AABBTree
  • To:
  • Subject: Re: [cgal-discuss] Bugs in AABBTree
  • Date: Wed, 12 Nov 2014 17:03:06 -0500
Hi Sebastien,
OK, we have tested your code.  It only fails with gcc 4.8.2 which happens to be the compiler we were using on both linux machines.
gcc version 4.4.7 (GCC) : OK
gcc version 4.7.2 (GCC) : OK
gcc version 4.8.2 (GCC): Failed
gcc version 4.9.2 (GCC): OK
It might have been a bug with gcc 4.8.2.  :(
best,
James
On Wed, Nov 12, 2014 at 3:31 PM, Sebastien Loriot (GeometryFactory) <> wrote:
I compiled the program attached on your input converted to off using
meshlab using
g++-4.8 (Debian 4.8.3-2) 4.8.3
g++-4.7 (Debian 4.7.3-14) 4.7.3
g++-4.6 (Debian 4.6.4-7) 4.6.4
g++-4.4 (Debian 4.4.7-8) 4.4.7
with CGAL-4.5 and all was fine.
Could you give it a try and let us know?
Thanks,
Sebastien.
On 11/12/2014 06:04 PM, Julian Panetta wrote:
Dear Sebastien and Laurent,
The main point of the example was to show that querying the AABB for a
triangle by its centroid is finding the incorrect triangle. The distance
printout shows that the error made is many orders of magnitude greater
than machine precision (the example mesh bounding box is
26.6x19.2x16.1). You can see a full printout of the large errors here:
http://julianpanetta.com/bad.txt
Notice that even when the AABB tree gets the correct face, sometimes the
distance is not close to zero:
11208
distance  = 0.0363889
face idx  = 11208
(the first number means the centroid of 11208 was queried, and face idx
= 11208 means the AABB returned face 11208).
It's difficult to believe this is a simple floating point error; the
example mesh doesn't have small or degenerate triangles, and the errors
are visually obvious:
http://julianpanetta.com/incorrect_result.png
(a query and the incorrectly retrieved triangle are outlined).
Furthermore, the results are compiler dependent: when gcc 4.8.2 is used
to compile CGAL and the example, both kernels Cartesian<double> and
Exact_predicates_inexact_constructions_kernel, give the incorrect AABB
results. When gcc 4.9.2 is used to compile CGAL and the example, both
kernels give the correct AABB results. It also works to compile CGAL
with gcc 4.8.2 but the example with gcc 4.9.2.
-Julian
On Wed, Nov 12, 2014 at 11:03 AM, Laurent Rineau (CGAL/GeometryFactory)
< <mailto:laurent.rineau@cgal.org>> wrote:
    Le Wednesday 12 November 2014 10:38:03 Qingnan Zhou a écrit :
    > Hi Sebastien,
    > Changing the kernel to CGAL::Exact_predicates_inexact_constructions_kernel
    > does not help in this case.  The closest point and primitive returned are
    > still incorrect for many faces.  However, switching to gcc-4.9.2 on linux
    > seems to make the problem go away.  Maybe it is related to how CGAL is
    > built?
    > Is anyone able to reproduce this problem?  I.e. compute the distance
    > between face center to the mesh for every face and check the distance is
    > 0.  Try it on this mesh: "suzanne.obj
     > <https://www.dropbox.com/s/j1xj8nfy68xpdqc/suzanne_tri.obj?dl=0>"
    The computation of a distance is a construction. With the kernel
    CGAL::Exact_predicates_inexact_constructions_kernel, then the
    constructions
    are not exact, and thus the computation of a distance is not exact
    either.
    That is expected.
    Please explain what sort of problem you want to solve, that is
    impacted by
    this "bug", and we might be able to propose other solutions.
    Laurent Rineau, PhD
