cgal-discuss - [cgal-discuss] Bugs in AABBTree
  • To:
  • Cc: Julian Panetta <>
  • Subject: [cgal-discuss] Bugs in AABBTree
  • Date: Mon, 10 Nov 2014 16:04:21 -0500
Dear all,
There seems to be a bug that causes CGAL::AABBTree to produce wrong results.  The following code would illustrate the problem:
It basically compute the center of each face and query the distance between the centroid and the mesh.  Ideally, the query should always return 0 as the distance and the source face index, otherwise the code will print out the face that causes the failure.
typedef CGAL::Cartesian<Real> K;
typedef K::Point_3 CGALPoint;
typedef K::Triangle_3 CGALTriangle;
typedef CGAL::AABB_tree<AABB_triangle_traits> AABBTree;
typedef AABBTree::Point_and_primitive_id Point_and_primitive_id;
    AABBTree *coarseTrianglesTree =
        new AABBTree(triangles.begin(), triangles.end());
    coarseTrianglesTree->accelerate_distance_queries();
    size_t count = 0;
    for (auto itr : triangles) {
        CGALPoint c = CGAL::ORIGIN + ((
        (itr[0] - CGAL::ORIGIN) +
        (itr[1] - CGAL::ORIGIN) +
        (itr[2] - CGAL::ORIGIN)) / 3.0);
        Point_and_primitive_id pp = coarseTrianglesTree->closest_point_and_primitive(c);
        size_t face_index = pp.second - triangles.begin();
        double distance = coarseTrianglesTree->squared_distance(c);
        if (distance > 1e-3) {
            std::cout << count << std::endl;
            std::cout << "distance  = " << distance << std::endl;
            std::cout << "face idx  = " << face_index << std::endl;
        count ++;
When running this test on meshes such as "suzanne.obj", the query fails on quite a few faces (the query finds the incorrect face index and gets a distance ~= 10^-3).
We are able to reproduce the error with CGAL 4.4 and CGAL 4.5 on
Redhat Enterprise Linux server with the following setting:
gcc 4.8.2, gmp 6.0.0 (also tried 4.3.1), mpfr 3.1.2, boost 1.53
CentOS 6.3 with the following setting:
gcc 4.8.2, gmp 6.0.0a, mpfr 3.1.2, boost 1.55.0
Strangely it works on the version compiled by macports.  We have tested CGAL 4.3 and 4.4 on mac.
best,
James
