- To:
- Subject: Re:[cgal-discuss] Having problem to install CGAL in window
- Date: Thu, 13 Nov 2014 09:23:18 +0800 (CST)
Boost library files need to be compiled firstly, make sure that you have done this!
At 2014-11-13 09:12:44, "dangphucbao" <> wrote: >I don't follow the website because it didn't work work. Cmake always said >that boost file is lack of file and the configuring is incomplete. > > > >-- >View this message in context: http://cgal-discuss.949826.n4.nabble.com/Having-problem-to-install-CGAL-in-window-tp4660093p4660099.html >Sent from the cgal-discuss mailing list archive at Nabble.com. > >-- >You are currently subscribed to cgal-discuss. >To unsubscribe or access the archives, go to >https://sympa.inria.fr/sympa/info/cgal-discuss > >
- [cgal-discuss] Having problem to install CGAL in window, dangphucbao, 11/12/2014
- Re: [cgal-discuss] Having problem to install CGAL in window, Sebastien Loriot (GeometryFactory), 11/12/2014
- Re: [cgal-discuss] Having problem to install CGAL in window, dangphucbao, 11/13/2014
- Re:[cgal-discuss] Having problem to install CGAL in window, 刘磊, 11/13/2014
- Re: [cgal-discuss] Having problem to install CGAL in window, Sebastien Loriot (GeometryFactory), 11/13/2014
