- To:
- Subject: Re: [cgal-discuss] Having problem to install CGAL in window
- Date: Thu, 13 Nov 2014 09:16:45 +0100
On 11/13/2014 02:12 AM, dangphucbao wrote:
I don't follow the website because it didn't work work. Cmake always said
that boost file is lack of file and the configuring is incomplete.
This tutorial has been tested several times by different persons on different machines so I can guarantee that what is written is correct.
Sebastien.
View this message in context:
http://cgal-discuss.949826.n4.nabble.com/Having-problem-to-install-CGAL-in-window-tp4660093p4660099.html
- [cgal-discuss] Having problem to install CGAL in window, dangphucbao, 11/12/2014
- Re: [cgal-discuss] Having problem to install CGAL in window, Sebastien Loriot (GeometryFactory), 11/12/2014
- Re: [cgal-discuss] Having problem to install CGAL in window, dangphucbao, 11/13/2014
- Re:[cgal-discuss] Having problem to install CGAL in window, 刘磊, 11/13/2014
- Re: [cgal-discuss] Having problem to install CGAL in window, Sebastien Loriot (GeometryFactory), 11/13/2014
