- To:
- Subject: [cgal-discuss] Having problem to install CGAL in window
- Date: Wed, 12 Nov 2014 10:12:28 -0800 (PST)
Hi all, I'm a new coder in programming CGAL
I have just install CGAL in win8 64bit with Cmake follow some steps here:
1) Install visual 2013 ultimate.
2) Install boost 1_56_0 (successfully, I have tested it on visual)
3) Install Cmake 3.0.2 and CGAL 4.5 .exe and restart the windows
4) Make project CGAL by CMake and it said: configuring done, generating
done.
5) I open project and run file .sln but it shows some errors
Error 103: error LNK2019: unresolved external symbol
"__declspec(dllimport) void __cdecl boost::detail::set_tss_data(void const
*,class boost::shared_ptr<struct boost::detail::tss_cleanup_function>,void
*,bool)"
(__imp_?set_tss_data@detail@boost@@YAXPEBXV?$shared_ptr@Utss_cleanup_function@detail@boost@@@2@PEAX_N@Z)
referenced in function "public: __cdecl
boost::thread_specific_ptr<int>::~thread_specific_ptr<int>(void)"
(??1?$thread_specific_ptr@H@boost@@QEAA@XZ) F:\CGAL 5\src\CGAL\all_files.obj
CGAL
Error 103 error LNK2019: unresolved external symbol "__declspec(dllimport)
class boost::system::error_category const & __cdecl
boost::system::generic_category(void)"
(__imp_?generic_category@system@boost@@YAAEBVerror_category@12@XZ)
referenced in function "void __cdecl boost::system::`dynamic initializer for
'errno_ecat''(void)" (??__Eerrno_ecat@system@boost@@YAXXZ) F:\CGAL
5\src\CGAL\all_files.obj CGAL
Error 104 error LNK1120: 3 unresolved externals F:\CGAL
5\bin\Debug\CGAL-vc120-mt-gd-4.5.dll CGAL
I hope you could help me to solve this problems, thanks you very much.
View this message in context:
http://cgal-discuss.949826.n4.nabble.com/Having-problem-to-install-CGAL-in-window-tp4660093.html
- [cgal-discuss] Having problem to install CGAL in window, dangphucbao, 11/12/2014
- Re: [cgal-discuss] Having problem to install CGAL in window, Sebastien Loriot (GeometryFactory), 11/12/2014
- Re: [cgal-discuss] Having problem to install CGAL in window, dangphucbao, 11/13/2014
- Re:[cgal-discuss] Having problem to install CGAL in window, 刘磊, 11/13/2014
- Re: [cgal-discuss] Having problem to install CGAL in window, Sebastien Loriot (GeometryFactory), 11/13/2014
