Re: [cgal-discuss] kd-tree crashing on Visual Studio 10/11 for x64 configuration
- To:
- Subject: Re: [cgal-discuss] kd-tree crashing on Visual Studio 10/11 for x64 configuration
- Date: Mon, 17 Nov 2014 23:22:10 +0100
Hello,
Can you post a data set. It might be that we have a fix,
as we recently noticed that when many points have one identical
coordinate the split does not happen in the middle.
Best regards,
Andreas
On 16/11/2014 22:33, nexxus wrote:
I have encountered the same issue on a different data set.
Configuration: Visual Studio 11, x64.
As Zohar already said: The recursive call to
Kd_tree::create_internal_node_use_extension() causes a stack overflow.
View this message in context:
http://cgal-discuss.949826.n4.nabble.com/kd-tree-crashing-on-Visual-Studio-10-11-for-x64-configuration-tp4659051p4660121.html
- Re: [cgal-discuss] kd-tree crashing on Visual Studio 10/11 for x64 configuration, nexxus, 11/16/2014
- Re: [cgal-discuss] kd-tree crashing on Visual Studio 10/11 for x64 configuration, Andreas Fabri, 11/17/2014
- Re: [cgal-discuss] kd-tree crashing on Visual Studio 10/11 for x64 configuration, Andreas Fabri, 11/19/2014
- Re: [cgal-discuss] kd-tree crashing on Visual Studio 10/11 for x64 configuration, cadietrich, 11/20/2014
