Re: [cgal-discuss] kd-tree crashing on Visual Studio 10/11 for x64 configuration
- To:
- Subject: Re: [cgal-discuss] kd-tree crashing on Visual Studio 10/11 for x64 configuration
- Date: Wed, 19 Nov 2014 07:55:55 +0100
Hello,
Can you check whether the bug fix in a splitter solves
your problem.
Best,
Andreas
On 16/11/2014 22:33, nexxus wrote:
I have encountered the same issue on a different data set.
Configuration: Visual Studio 11, x64.
As Zohar already said: The recursive call to
Kd_tree::create_internal_node_use_extension() causes a stack overflow.
View this message in context:
http://cgal-discuss.949826.n4.nabble.com/kd-tree-crashing-on-Visual-Studio-10-11-for-x64-configuration-tp4659051p4660121.html
Andreas Fabri, PhD
Chief Officer, GeometryFactory
Editor, The CGAL Project
phone: +33.492.954.912 skype: andreas.fabri
// Copyright (c) 2002-2011 Utrecht University (The Netherlands).
// All rights reserved.
// This file is part of CGAL (www.cgal.org).
// You can redistribute it and/or modify it under the terms of the GNU
// General Public License as published by the Free Software Foundation,
// either version 3 of the License, or (at your option) any later version.
// Licensees holding a valid commercial license may use this file in
// accordance with the commercial license agreement provided with the
software.
// This file is provided AS IS with NO WARRANTY OF ANY KIND, INCLUDING THE
// WARRANTY OF DESIGN, MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE.
// $URL$
// $Id$
// Author(s) : Hans Tangelder
// Defines rules used for constructing a split node. That is, it implements,
// in several ways, the concept
// Boxtree_splitter<FT>.
#ifndef CGAL_SPLITTERS_H
#define CGAL_SPLITTERS_H
#include <CGAL/Point_container.h>
#include <CGAL/Plane_separator.h>
namespace CGAL {
template <class FT>
class Splitter_base {
private:
unsigned int the_bucket_size;
FT the_aspect_ratio;
public:
//default bucket_size should be 10
Splitter_base(unsigned int bucket_size = 10,
FT aspect_ratio = FT(3))
: the_bucket_size(bucket_size),
the_aspect_ratio(aspect_ratio)
FT
aspect_ratio() const
return the_aspect_ratio;
unsigned int
bucket_size() const
return the_bucket_size;
template <class SearchTraits,
class Separator_= Plane_separator<typename SearchTraits::FT> >
class Median_of_max_spread
: public Splitter_base<typename SearchTraits::FT>
typedef Splitter_base<typename SearchTraits::FT> Base;
public:
typedef typename SearchTraits::FT FT;
typedef Point_container<SearchTraits> Container;
typedef Separator_ Separator;
Median_of_max_spread()
: Base()
Median_of_max_spread(unsigned int bucket_size)
: Base(bucket_size)
void
operator() (Separator& sep,
Container& c0,
Container& c1) const
sep=Separator(c0.max_tight_span_coord(),FT(0));
sep.set_cutting_value(c0.median(sep.cutting_dimension()));
c0.split(c1,sep,true);
class Fair
public:
Fair()
: Base()
Fair(unsigned int bucket_size,
FT aspect_ratio=FT(3))
: Base(bucket_size, aspect_ratio)
void
operator()(Separator& sep, Container& c0, Container& c1) const
// find legal cut with max spread
sep=Separator(c0.max_tight_span_coord_balanced(this->aspect_ratio()),
FT(0));
sep.set_cutting_value(c0.balanced_fair(sep.cutting_dimension(),
this->aspect_ratio()));
c0.split(c1,sep);
class Sliding_fair
public:
Sliding_fair()
: Base()
Sliding_fair(unsigned int bucket_size,
void
operator() (Separator& sep, Container& c0, Container& c1) const
sep = Separator(c0.max_tight_span_coord_balanced(this->aspect_ratio()),
FT(0));
sep.set_cutting_value(c0.balanced_sliding_fair(sep.cutting_dimension(),
class Sliding_midpoint
public:
Sliding_midpoint()
: Base()
Sliding_midpoint(unsigned int bucket_size)
: Base(bucket_size)
void
CGAL_assertion(c0.is_valid());
CGAL_assertion(c1.is_valid());
int cutdim = c0.max_span_coord();
//Bugfix: avoid linear tree in degenerated cases
if(c0.tight_bounding_box().min_coord(cutdim) !=
c0.tight_bounding_box().max_coord(cutdim)){
sep = Separator(cutdim,
(c0.max_span_upper() +
c0.max_span_lower())/FT(2));
else{
cutdim = c0.max_tight_span_coord();
(c0.max_tight_span_upper() +
c0.max_tight_span_lower())/FT(2));
FT max_span_lower =
c0.tight_bounding_box().min_coord(cutdim);
CGAL_assertion(max_span_lower >= c0.bounding_box().min_coord(cutdim));
FT max_span_upper =
c0.tight_bounding_box().max_coord(cutdim);
CGAL_assertion(max_span_upper <= c0.bounding_box().max_coord(cutdim));
if (max_span_upper <= sep.cutting_value()) {
sep.set_cutting_value(max_span_upper);
if (max_span_lower >= sep.cutting_value()) {
sep.set_cutting_value(max_span_lower);
class Median_of_rectangle
public:
Median_of_rectangle()
: Base()
Median_of_rectangle(unsigned int bucket_size)
: Base(bucket_size)
void
sep = Separator(c0.max_span_coord(),FT(0));
class Midpoint_of_max_spread
public:
Midpoint_of_max_spread()
: Base()
Midpoint_of_max_spread(unsigned int bucket_size)
: Base(bucket_size)
void
sep = Separator(c0.max_tight_span_coord(),
c0.split(c1,sep);
class Midpoint_of_rectangle
public:
Midpoint_of_rectangle()
: Base()
Midpoint_of_rectangle(unsigned int bucket_size)
: Base(bucket_size)
void
(c0.max_span_upper() + c0.max_span_lower())/FT(2));
c0.split(c1,sep);
} // namespace CGAL
#endif // CGAL_SPLITTERS
- Re: [cgal-discuss] kd-tree crashing on Visual Studio 10/11 for x64 configuration, nexxus, 11/16/2014
- Re: [cgal-discuss] kd-tree crashing on Visual Studio 10/11 for x64 configuration, Andreas Fabri, 11/17/2014
- Re: [cgal-discuss] kd-tree crashing on Visual Studio 10/11 for x64 configuration, Andreas Fabri, 11/19/2014
- Re: [cgal-discuss] kd-tree crashing on Visual Studio 10/11 for x64 configuration, cadietrich, 11/20/2014
