cgal-discuss - [cgal-discuss] Example Compiling Issue
  • To:
  • Subject: [cgal-discuss] Example Compiling Issue
  • Date: Tue, 18 Nov 2014 11:18:54 -0800
Hello,
I am having some issues compiling an example from Surface reconstruction
part. It'd be great if someone can point out what could be the issue.
I am using Mac OS 10.8 and cgal 4.4
dn525jo5:poisson_rec hardik$ port list cgal
Warning: port definitions are more than two weeks old, consider updating them by running 'port selfupdate'.
cgal                           @4.4            gis/cgal
Compiling error:
/usr/local/soft/UM++/hardik/3Dexamples/FromTrianles/brain/cowBrainModel/poisson_rec/poisson_reconstruction_withUMesh.cpp:64:21: error: no matching member function for call
      to 'compute_implicit_function'
    if ( ! function.compute_implicit_function() )
/opt/local/include/CGAL/Poisson_reconstruction_function.h:375:8: note: candidate function template not viable: requires at least 2 arguments, but 0 were provided
  bool compute_implicit_function(
/opt/local/include/CGAL/Poisson_reconstruction_function.h:528:8: note: candidate function template not viable: requires at least argument 'solver', but no arguments were
      provided
  bool compute_implicit_function(SparseLinearAlgebraTraits_d solver, bool smoother_hole_filling = false)
Excerpt from the .cpp
  PointList points;
    std::ifstream stream("data/kitten.xyz");
    if (!stream ||
        !CGAL::read_xyz_points_and_normals(
                              stream,
                              std::back_inserter(points),
                              CGAL::make_normal_of_point_with_normal_pmap(PointList::value_type())))
      std::cerr << "Error: cannot read file data/kitten.xyz" << std::endl;
      return EXIT_FAILURE;
    // Creates implicit function from the read points using the default solver.
    // Note: this method requires an iterator over points
    // + property maps to access each point's position and normal.
    // The position property map can be omitted here as we use iterators over Point_3 elements.
    Poisson_reconstruction_function function(points.begin(), points.end(),
                                             CGAL::make_normal_of_point_with_normal_pmap(PointList::value_type()) );
    // Computes the Poisson indicator function f()
    // at each vertex of the triangulation.
Thanks!
Hardik Kabaria
Hardik Kabaria
Ph.D. Candidate
Department of Mechanical Engineering
Stanford University
