- To:
- Subject: Re: [cgal-discuss] struggling opening off file
- Date: Tue, 25 Nov 2014 21:13:34 +0100
Hi Alexandre,
the orientation of the faces is not coherent.
The first face has a halfedge from vertex 0 to 3.
So the fifth face should have the opposite
orientation as it should have a halfedge from
vertex 3 to 0.
It might be a good idea that we reorient
faces automatically.
best,
andreas
On 25/11/2014 20:11, Alexandre Lapene wrote:
Hi,
I'm struggling opening an off file that I have generated.
Here is the simple piece of work that does not work
Polyhedron mesh;
std::ifstream input("file.off");
if (!input) {
cerr << "Cannot open file!\n";
return EXIT_FAILURE;
if (!(input >> mesh) || mesh.empty()) {
std::cerr << "Not a valid off file." << std::endl;
The code exists at the second test as the file is found but appears not
correct and it's seen as empty.
Below is my off file
OFF
8 6 0
5.59796 5.80733 -0.000205
5.94914 5.35456 -0.000225
5.94926 5.35465 0.094035
5.59808 5.80742 0.094055
5.54866 5.76909 -0.000107
5.89984 5.31632 -0.000127
5.89996 5.31641 0.094133
5.54878 5.76918 0.094153
4 0 3 2 1
4 4 7 6 5
4 1 0 4 5
4 3 2 6 7
4 0 3 7 4
4 1 2 6 5
Just a simple box. I have tried to open it and save it as off in Meshlab but
it does change the result.
I have also tried with a cube
OFF
8 6 0
0 1 0
0 0 0
0 0 1
1 0 0
1 0 1
0 1 1
1 1 0
1 1 1
4 3 4 2 1
4 0 6 3 1
4 6 0 5 7
4 5 0 1 2
4 7 5 2 4
4 7 4 3 6
It works with this cube.
So, my question is what's wrong with my off file? And is there some debug
info I can access to know what's wrong in general in one off file I would
like to open and use
Thanks in advance
View this message in context:
http://cgal-discuss.949826.n4.nabble.com/struggling-opening-off-file-tp4660163.html
Andreas Fabri, PhD
Chief Officer, GeometryFactory
Editor, The CGAL Project
phone: +33.492.954.912 skype: andreas.fabri
- [cgal-discuss] struggling opening off file, Alexandre Lapene, 11/25/2014
- Re: [cgal-discuss] struggling opening off file, Andreas Fabri, 11/25/2014
- Re: [cgal-discuss] struggling opening off file, Alexandre Lapene, 11/25/2014
- Re: [cgal-discuss] struggling opening off file, Andreas Fabri, 11/26/2014
- Re: [cgal-discuss] struggling opening off file, Alexandre Lapene, 11/26/2014
- Re: [cgal-discuss] struggling opening off file, Alexandre Lapene, 11/27/2014
