cgal-discuss - Re: [cgal-discuss] MinGW issues
  • To:
  • Subject: Re: [cgal-discuss] MinGW issues
  • Date: Wed, 26 Nov 2014 16:21:51 +0100
Le Wednesday 26 November 2014 14:59:46 xantares 09 a écrit :
> Hello,
> I've got issues cross-compiling CGAL 4.5 with MinGW64 (mingw-gcc 4.9.1) from
Hi! So far CGAL does not support the MinGW(64) compiler. Your help is
appreciated.
> 1. There's a compilation error with the x86_64 target:
> But if I replace _MSC_VER by _WIN32 in include/CGAL/sse2.h, both i686 and
> x86_64 targets are fine:
> #if defined ( _WIN32 )
> #define CGAL_ALIGN_16 __declspec(align(16))
> #elif defined( __GNU__ )
> #define CGAL_ALIGN_16 __attribute__((aligned(16)))
> #endif
Thanks. I will integrate that patch into CGAL-4.6.
> 2. Export libraries (.dll) are properly installed to <PREFIX>/bin and import
> libraries (.dll.a) to <PREFIX>/lib.
> But in the CGALConfig.cmake file, the CGAL*_LIBRARY vars refer to
> the export library name in <PREFIX>/lib:
> set(CGAL_LIBRARY "/usr/i686-w64-mingw32/lib/libCGAL.dll")
> it should be the import library:
> set(CGAL_LIBRARY "/usr/i686-w64-mingw32/lib/libCGAL.dll.a")
Do you have a patch to our CMake scripts?
Laurent Rineau, PhD
