- To: "" <>
- Subject: RE: [cgal-discuss] MinGW issues
- Date: Sat, 29 Nov 2014 11:42:30 +0000
- Importance: Normal
> From:
> To:
> Date: Fri, 28 Nov 2014 17:45:21 +0100
> Subject: Re: [cgal-discuss] MinGW issues
> Le Friday 28 November 2014 16:24:43 xantares 09 a écrit :
> > > From:
> > > To:
> > > Date: Thu, 27 Nov 2014 13:18:36 +0100
> > > Le Wednesday 26 November 2014 14:59:46 xantares 09 a écrit :
> > > > Hello,
> > > > I've got issues cross-compiling CGAL 4.5 with MinGW64 (mingw-gcc 4.9.1)
> > > > from
> > > > linux (x86_64 host).
> > > Can you post an email explaining how you did that with CMake? What
> > > toolchain file have you used, and how have you solved all the issue of
> > > system introspection?
> > Will these two patches be included in the next release ?
> The first patch on <CGAL/sse2.h> is being integrated in the future CGAL-4.5.1
> bug-fix release, and in our 'master' Git branch. The second patch on the CMake
> scripts is more questionable. We are currently redoing all our CMake scripts,
> and your patch is probably not worth being integrated in 'master'.
Maybe I can test a master snaphshot when it's ready.
> As for the CGAL-4.5 branch, I want to test your MinGW setup before modifying
> the CMake scripts, but I have not had the time so far.
> > Do you have a public repo ?
> Unfortunately, not yet. There is an ongoing work to publish our Git repository
> on Github. I hope that it will be finished during the first trimester of 2015.
> Laurent Rineau, PhD
> R&D Engineer at GeometryFactory http://www.geometryfactory.com/
> Release Manager of the CGAL Project http://www.cgal.org/
> You are currently subscribed to cgal-discuss.
> To unsubscribe or access the archives, go to
> https://sympa.inria.fr/sympa/info/cgal-discuss
> To:
> > > From:
> > > To:
> > > > Hello,
> > > > from
> Laurent Rineau, PhD
- [cgal-discuss] MinGW issues, xantares 09, 11/26/2014
- Re: [cgal-discuss] MinGW issues, Laurent Rineau (CGAL/GeometryFactory), 11/26/2014
- RE: [cgal-discuss] MinGW issues, xantares 09, 11/27/2014
- Re: [cgal-discuss] MinGW issues, Laurent Rineau (CGAL/GeometryFactory), 11/27/2014
- RE: [cgal-discuss] MinGW issues, xantares 09, 11/28/2014
- Re: [cgal-discuss] MinGW issues, Laurent Rineau (CGAL/GeometryFactory), 11/28/2014
- RE: [cgal-discuss] MinGW issues, xantares 09, 11/29/2014
