- To:
- Subject: Re: [cgal-discuss] struggling opening off file
- Date: Wed, 26 Nov 2014 09:56:48 -0800 (PST)
Thanks Andreas.
I have read some posts about the coplanarity and I understand now.
The data I have are computed generated data from a deposition code. The
precision is double which leads to a non coplanar vertices strictly
speaking.
Actually I have a bunch of boxes and I would like to apply some booleans on
them. So, I need to go through Nef_polyhedron and the only way is to
transform my polyhedron to make its vertices coplanar regarding the facets.
What would you suggest?
Alexandre
View this message in context:
http://cgal-discuss.949826.n4.nabble.com/struggling-opening-off-file-tp4660163p4660179.html
- [cgal-discuss] struggling opening off file, Alexandre Lapene, 11/25/2014
- Re: [cgal-discuss] struggling opening off file, Andreas Fabri, 11/25/2014
- Re: [cgal-discuss] struggling opening off file, Alexandre Lapene, 11/25/2014
- Re: [cgal-discuss] struggling opening off file, Andreas Fabri, 11/26/2014
- Re: [cgal-discuss] struggling opening off file, Alexandre Lapene, 11/26/2014
- Re: [cgal-discuss] struggling opening off file, Alexandre Lapene, 11/27/2014
