- To:
- Subject: Re: [cgal-discuss] struggling opening off file
- Date: Thu, 27 Nov 2014 11:00:28 -0800 (PST)
Thanks for your answer
I did the triangulation with MeshLab. I had assumed it was correct. I will
double check
I will also try the triangulation through
CGAL::triangulate_polyhedron(Polyhedron&)
I'll let you know
Alexandre
View this message in context:
http://cgal-discuss.949826.n4.nabble.com/struggling-opening-off-file-tp4660163p4660185.html
- [cgal-discuss] struggling opening off file, Alexandre Lapene, 11/25/2014
- Re: [cgal-discuss] struggling opening off file, Andreas Fabri, 11/25/2014
- Re: [cgal-discuss] struggling opening off file, Alexandre Lapene, 11/25/2014
- Re: [cgal-discuss] struggling opening off file, Andreas Fabri, 11/26/2014
- Re: [cgal-discuss] struggling opening off file, Alexandre Lapene, 11/26/2014
- Re: [cgal-discuss] struggling opening off file, Alexandre Lapene, 11/27/2014
