- To:
- Subject: Re: [cgal-discuss] offset_polygon_2 upon offset_polygon_2
- Date: Wed, 3 Dec 2014 12:46:15 +0200
I'm afraid not.
The input is restricted to a "standard" polygon (or polygon with holes), which can be represented by a sequence (or sequences if it has holes) of points for example. ____ _ ____ _
/_____/_) o /__________ __ //
(____ ( ( ( (_/ (_/-(-'_(/
_/
_/
On Mon, Dec 1, 2014 at 10:42 PM, Lars Ole Belhage <> wrote:
Hello,
Running the many of the small test programs has convinced me of the
versatility and elegance of the CGAL.
Now, I'm trying to find a way to run the output of offset_polygon_2 into
another offset_polygon_2. But after browsing documentation, I'm getting
a little worried - can the "offset" algorithms work with polygons with
arcs (or splines) in them ?
If "yes", I will dig deeper and get the right traits to my data (but an
simple extension of the the Minkowski_sum_2/exact_offset.cpp to do the
sum several times, would of course be of great help)
If "no", well...
Great Salutions
Belhage
- [cgal-discuss] offset_polygon_2 upon offset_polygon_2, Lars Ole Belhage, 12/01/2014
- Re: [cgal-discuss] offset_polygon_2 upon offset_polygon_2, Efi Fogel, 12/03/2014
- Re: [cgal-discuss] offset_polygon_2 upon offset_polygon_2, Lars Ole Belhage, 12/03/2014
