cgal-discuss - Re: [cgal-discuss] offset_polygon_2 upon offset_polygon_2
  • To:
  • Subject: Re: [cgal-discuss] offset_polygon_2 upon offset_polygon_2
  • Date: Wed, 03 Dec 2014 15:54:45 +0100
Great - then I might have a way to solve my problem.
Thanks a lot
Belhage
On Wed, 2014-12-03 at 16:50 +0200, Efi Fogel wrote:
> On Wed, Dec 3, 2014 at 4:45 PM, Lars Ole Belhage
> wrote:
> Ok - thanks for a quick answer, spared me for trying in vain!
> But the boolean operations takes generalized polygons ?
> Indeed.
> Many regards
> Belhage
> On Wed, 2014-12-03 at 12:46 +0200, Efi Fogel wrote:
> > I'm afraid not.
> > The input is restricted to a "standard" polygon (or polygon
> with
> > holes), which can be represented by a sequence (or sequences
> if it has
> > holes) of points for example.
> > The output is what we call a generalized polygon (or a
> generalized
> > polygon with wholes.) A generalized polygon must be
> represented by a
> > sequence (or sequences if it has holes) of curves.
> > Computing the Minkowski sum or even the offset of a
> generalized
> > polygon, I think, is much more complicated.
> > ____ _ ____ _
> > /_____/_) o /__________ __ //
> > (____ ( ( ( (_/ (_/-(-'_(/
> > _/
> > On Mon, Dec 1, 2014 at 10:42 PM, Lars Ole Belhage
> wrote:
> > Hello,
> > Running the many of the small test programs has
> convinced me
> > of the
> > versatility and elegance of the CGAL.
> > Now, I'm trying to find a way to run the output of
> > offset_polygon_2 into
> > another offset_polygon_2. But after browsing
> documentation,
> > I'm getting
> > a little worried - can the "offset" algorithms work
> with
> > polygons with
> > arcs (or splines) in them ?
> > If "yes", I will dig deeper and get the right traits
> to my
> > data (but an
> > simple extension of the the
> Minkowski_sum_2/exact_offset.cpp
> > to do the
> > sum several times, would of course be of great help)
> > If "no", well...
> > Great Salutions
> > Belhage
> > You are currently subscribed to cgal-discuss.
> > To unsubscribe or access the archives, go to
> > https://sympa.inria.fr/sympa/info/cgal-discuss
