- To:
- Subject: Re: [cgal-discuss] Epick convex_hull_3 assertion
- Date: Tue, 6 Jan 2015 10:30:27 -0500
Hi Sebastien,
See my attached test program.
The problem appears to be that convex_hull_3() doesn’t accept a std::set
iterator, alternatively that Epick::Point_3’s equality operator isn’t
performing as expected.
Any idea?
It looks like I can work around this by building vectors or lists and let the
convex hull function deal with duplicate vertices.
..but you might want to figure this out :)
-Marius
collinear2.cpp
Description: Binary data
On Jan 6, 2015, at 02:36 AM, Sebastien Loriot (GeometryFactory)
wrote:
> I just tried and the convex hull is fine here.
> Could you please double check? In particular because
> in 4.5 only the handling of coplanar points has been changed.
> If you still have the pb, please let me know what I should do
> to reproduce the pb.
> Thanks,
> Sebastien.
- [cgal-discuss] Epick convex_hull_3 assertion, Marius Kintel, 01/03/2015
- Re: [cgal-discuss] Epick convex_hull_3 assertion, Marc Glisse, 01/03/2015
- Re: [cgal-discuss] Epick convex_hull_3 assertion, Sebastien Loriot (GeometryFactory), 01/04/2015
- Re: [cgal-discuss] Epick convex_hull_3 assertion, Marius Kintel, 01/04/2015
- Re: [cgal-discuss] Epick convex_hull_3 assertion, Sebastien Loriot (GeometryFactory), 01/05/2015
- Re: [cgal-discuss] Epick convex_hull_3 assertion, Marius Kintel, 01/05/2015
- Re: [cgal-discuss] Epick convex_hull_3 assertion, Sebastien Loriot (GeometryFactory), 01/06/2015
- Re: [cgal-discuss] Epick convex_hull_3 assertion, Marius Kintel, 01/06/2015
- Re: [cgal-discuss] Epick convex_hull_3 assertion, Sebastien Loriot (GeometryFactory), 01/07/2015
