- To:
- Subject: [cgal-discuss] the strange result of odt-optimization in mesh_3_example
- Date: Sat, 24 Jan 2015 00:41:18 +0800
Hi all,
I use project "mesh_polyhedral_domain_with_features" in mesh_3_example.sln. The inputting file as polyhedral domain is attached. I changed the .cpp file is as follows.
int main()
// Create domain
Mesh_domain domain("D:/Program Files (x86)/CGAL-3.8/examples/Mesh_3/data/boxsub2cyl.off");
// Get sharp features
domain.detect_features();
// Mesh criteria
Mesh_criteria criteria(edge_size = 2.5,
facet_angle = 25, facet_size = 2.5, facet_distance = 0.5,
cell_radius_edge_ratio = 3, cell_size = 2.5);
// Mesh generation
std::cout<<"Mesh generation ...";
C3t3 c3t3 = CGAL::make_mesh_3<C3t3>(domain, criteria);
std::ofstream medit_file("boxsub2cyl_features.mesh");
c3t3.output_to_medit(medit_file);
medit_file.close();
//ODT optimization
CGAL::odt_optimize_mesh_3(c3t3, domain, time_limit=30);
std::ofstream medit_file_odt("boxsub2cyl_features_odt.mesh");
c3t3.output_to_medit(medit_file_odt);
medit_file_odt.close();
//Exude
std::cout<<"Exude optimization ...";
CGAL::exude_mesh_3(c3t3, sliver_bound=10, time_limit=10);
std::cout<<" done"<<std::endl;
std::ofstream medit_file_exu("boxsub2cyl_features_exu.mesh");
c3t3.output_to_medit(medit_file_exu);
medit_file_exu.close();
It runs successfully. Then I transform the result files into .vtk file to view results. The result after make_mesh_3() is fine. But boxsub2cyl_features_odt is strange. It misses some tets and becomes rough and uneven in surface. It seems that the surface doesn't respect the domain. The domain odt_optimization_mesh_3() used is also features-caught. It should keep the features like make_mesh_3(). It is confusing.
Any reply is appreciated.
Shang Fei-Fei
boxsub2cyl.off
Description: Binary data
- [cgal-discuss] the strange result of odt-optimization in mesh_3_example, Shang Feifei, 01/23/2015
- Re: [cgal-discuss] the strange result of odt-optimization in mesh_3_example, Shang Feifei, 01/24/2015
