cgal-discuss - Re: [cgal-discuss] Parallel Delaunay triangulation construction. Compilation error.
  • To:
  • Subject: Re: [cgal-discuss] Parallel Delaunay triangulation construction. Compilation error.
  • Date: Fri, 23 Jan 2015 17:27:49 +0100
Le Friday 23 January 2015 19:15:22 Илья Палачев a écrit :
> Hi, all.
> I'm using example Triangulation_3/parallel_insertion_in_delaunay_3.cpp.
> The code that is used looks as follows:
That piece of code in Triangulation_3/parallel_insertion_in_delaunay_3.cpp
can
be compiled only if CGAL_LINKED_WITH_TBB is defined. If you do not use CGAL
CMake script to create your build system or solution, then you must define
that macro yourself.
Laurent Rineau, PhD
