Re: [cgal-discuss] Parallel Delaunay triangulation construction. Compilation error.
- To:
- Subject: Re: [cgal-discuss] Parallel Delaunay triangulation construction. Compilation error.
- Date: Sat, 24 Jan 2015 16:25:07 +0100
On Fri, Jan 23, 2015 at 5:46 PM, Илья Палачев
wrote:
> 23.01.2015, 19:28, "Laurent Rineau (CGAL/GeometryFactory)"
> > That piece of code in
> > Triangulation_3/parallel_insertion_in_delaunay_3.cpp can
> > be compiled only if CGAL_LINKED_WITH_TBB is defined. If you do not use
> > CGAL
> > CMake script to create your build system or solution, then you must define
> > that macro yourself.
> Ok. That helped!
> One little question:
> Triangulation::Lock_data_structure locking_ds(
> CGAL::Bbox_3(-1., -1., -1., 1., 1., 1.), 50);
> What does number "50" mean in this example. I failed to find any
> documentation about constructors of Lock_data_structure.
By default, CGAL::Delaunay_triangulation_3::Lock_data_structure is a
CGAL::Spatial_lock_grid_3:
http://doc.cgal.org/latest/STL_Extension/classCGAL_1_1Spatial__lock__grid__3.html
See section "Template parameters" => SurjectiveLockDataStructure on
this page for more details:
http://doc.cgal.org/latest/Triangulation_3/classCGAL_1_1Delaunay__triangulation__3.html
Clément
- [cgal-discuss] Parallel Delaunay triangulation construction. Compilation error., Илья Палачев, 01/23/2015
- Re: [cgal-discuss] Parallel Delaunay triangulation construction. Compilation error., Laurent Rineau (CGAL/GeometryFactory), 01/23/2015
- Re: [cgal-discuss] Parallel Delaunay triangulation construction. Compilation error., Илья Палачев, 01/23/2015
- Re: [cgal-discuss] Parallel Delaunay triangulation construction. Compilation error., Clément Jamin, 01/24/2015
- [cgal-discuss] MinGW 64 Compilation error, Vincent Rouvreau, 01/26/2015
