Re: [cgal-discuss] CGAL::Parallel_tag not compatible with CGAL::Triangulation_vertex_base_with_info_3
- To:
- Subject: Re: [cgal-discuss] CGAL::Parallel_tag not compatible with CGAL::Triangulation_vertex_base_with_info_3
- Date: Mon, 2 Feb 2015 00:53:19 -0800
┌─[adam][Hapkido][±][parallel ✓][~/CDT-plusplus]
└─▪ ./build.sh
-- The C compiler identification is AppleClang 6.0.0.6000056
-- The CXX compiler identification is AppleClang 6.0.0.6000056
-- Check for working C compiler using: Ninja
-- Check for working C compiler using: Ninja -- works
-- Detecting C compiler ABI info
-- Detecting C compiler ABI info - done
-- Check for working CXX compiler using: Ninja
-- Check for working CXX compiler using: Ninja -- works
-- Detecting CXX compiler ABI info
-- Detecting CXX compiler ABI info - done
-- Build type: Release
-- USING CXXFLAGS = ' -O3 -DNDEBUG'
-- USING EXEFLAGS = ' -Wl,-dylib_file,/System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGL.dylib:/System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGL.dylib '
-- Targetting Ninja
-- Using /usr/bin/c++ compiler.
-- DARWIN_VERSION=14
-- Mac Leopard detected
-- Requested component: Core
-- Requested component: MPFR
-- Requested component: GMP
-- Found Eigen3: /usr/local/include/eigen3 (found suitable version "3.2.3", minimum required is "3.1.0")
-- Found Intel TBB
-- Configuring done
-- Generating done
-- Build files have been written to: /Users/adam/CDT-plusplus/build
[11/12] Linking CXX executable cdt
I enabled it in my CMakeLists.txt:
# Experimental TBB support
# TBB 4.3 compatibility fixed in CGAL 4.5.1
find_package( TBB QUIET)
if (TBB_FOUND)
include( ${TBB_USE_FILE})
list(APPEND CGAL_3RD_PARTY_LIBRARIES ${TBB_LIBRARIES})
endif()
On Sun, 1 Feb 2015, Adam Getchell wrote:
FAILED: : && /usr/bin/c++ -O3 -DNDEBUG -Wl,-search_paths_first -Wl,-headerpad_max_install_names-Wl,-dylib_file,/System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGL.dylib:/System/Library/Frameworks/OpenGL.fram
ework/Versions/A/Libraries/libGL.dylib CMakeFiles/cdt.dir/src/cdt.cpp.o CMakeFiles/cdt.dir/src/docopt/docopt.cpp.o -o cdt
-L/usr/local/Cellar/cgal/4.5.1/lib /usr/local/lib/libmpfr.dylib /usr/local/lib/libgmp.dylib
/usr/local/Cellar/cgal/4.5.1/lib/libCGAL_Core.dylib /usr/local/Cellar/cgal/4.5.1/lib/libCGAL.dylib
/usr/local/lib/libboost_thread-mt.dylib /usr/local/lib/libboost_system-mt.dylib /usr/local/Cellar/cgal/4.5.1/lib/libCGAL_Core.dylib
/usr/local/Cellar/cgal/4.5.1/lib/libCGAL.dylib /usr/local/lib/libboost_thread-mt.dylib /usr/local/lib/libboost_system-mt.dylib
-Wl,-rpath,/usr/local/Cellar/cgal/4.5.1/lib && :
I don't see any mention of TBB on this line...
Marc Glisse
- [cgal-discuss] CGAL::Parallel_tag not compatible with CGAL::Triangulation_vertex_base_with_info_3, Adam Getchell, 02/02/2015
- Re: [cgal-discuss] CGAL::Parallel_tag not compatible with CGAL::Triangulation_vertex_base_with_info_3, Marc Glisse, 02/02/2015
- Re: [cgal-discuss] CGAL::Parallel_tag not compatible with CGAL::Triangulation_vertex_base_with_info_3, Adam Getchell, 02/02/2015
