Re: [cgal-discuss] CGAL::Parallel_tag not compatible with CGAL::Triangulation_vertex_base_with_info_3
- To:
- Subject: Re: [cgal-discuss] CGAL::Parallel_tag not compatible with CGAL::Triangulation_vertex_base_with_info_3
- Date: Mon, 2 Feb 2015 01:16:13 -0800
┌─[adam][Hapkido][±][parallel ✓][~/CDT-plusplus]
└─▪ ./build.sh
-- The C compiler identification is AppleClang 6.0.0.6000056
-- The CXX compiler identification is AppleClang 6.0.0.6000056
-- Check for working C compiler using: Ninja
-- Check for working C compiler using: Ninja -- works
-- Detecting C compiler ABI info
-- Detecting C compiler ABI info - done
-- Check for working CXX compiler using: Ninja
-- Check for working CXX compiler using: Ninja -- works
-- Detecting CXX compiler ABI info
-- Detecting CXX compiler ABI info - done
-- Build type: Release
-- USING CXXFLAGS = ' -O3 -DNDEBUG'
-- USING EXEFLAGS = ' -Wl,-dylib_file,/System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGL.dylib:/System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGL.dylib '
-- Targetting Ninja
-- Using /usr/bin/c++ compiler.
-- DARWIN_VERSION=14
-- Mac Leopard detected
-- Requested component: Core
-- Requested component: MPFR
-- Requested component: GMP
-- Found Eigen3: /usr/local/include/eigen3 (found suitable version "3.2.3", minimum required is "3.1.0")
-- Found Intel TBB
-- Configuring done
-- Generating done
-- Build files have been written to: /Users/adam/CDT-plusplus/build
[12/12] Linking CXX executable unittests
FAILED: : && /usr/bin/c++ -O3 -DNDEBUG -Wl,-search_paths_first -Wl,-headerpad_max_install_names -Wl,-dylib_file,/System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGL.dylib:/System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGL.dylib CMakeFiles/unittests.dir/unittests/main.cpp.o CMakeFiles/unittests.dir/unittests/PointTest.cpp.o CMakeFiles/unittests.dir/unittests/S3BulkActionTest.cpp.o CMakeFiles/unittests.dir/unittests/S3ErgodicMovesTest.cpp.o CMakeFiles/unittests.dir/unittests/S3TetrahedronTest.cpp.o CMakeFiles/unittests.dir/unittests/SdTriangulationTest.cpp.o CMakeFiles/unittests.dir/unittests/SphereTest.cpp.o CMakeFiles/unittests.dir/unittests/Triangulated2SphereTest.cpp.o -o unittests -L/usr/local/Cellar/cgal/4.5.1/lib -L/Users/adam/gmock-1.7.0/lib/.libs -L/Users/adam/gmock-1.7.0/gtest/lib/.libs /usr/local/lib/libmpfr.dylib /usr/local/lib/libgmp.dylib /usr/local/Cellar/cgal/4.5.1/lib/libCGAL_Core.dylib /usr/local/Cellar/cgal/4.5.1/lib/libCGAL.dylib /usr/local/lib/libboost_thread-mt.dylib /usr/local/lib/libboost_system-mt.dylib -lgmock -lgtest -lpthread -Wl,-rpath,/usr/local/Cellar/cgal/4.5.1/lib -Wl,-rpath,/Users/adam/gmock-1.7.0/lib/.libs -Wl,-rpath,/Users/adam/gmock-1.7.0/gtest/lib/.libs && :
Undefined symbols for architecture x86_64:
"tbb::queuing_mutex::scoped_lock::acquire(tbb::queuing_mutex&)", referenced from:
CGAL::Concurrent_compact_container<CGAL::Triangulation_cell_base_with_info_3<unsigned int, CGAL::Epick, CGAL::Triangulation_cell_base_3<CGAL::Epick, CGAL::Triangulation_ds_cell_base_3<CGAL::Triangulation_data_structure_3<CGAL::Triangulation_vertex_base_with_info_3<unsigned int, CGAL::Epick, CGAL::Triangulation_vertex_base_3<CGAL::Epick, CGAL::Triangulation_ds_vertex_base_3<void> > >, CGAL::Triangulation_cell_base_with_info_3<unsigned int, CGAL::Epick, CGAL::Triangulation_cell_base_3<CGAL::Epick, CGAL::Triangulation_ds_cell_base_3<void> > >, CGAL::Parallel_tag> > > >, tbb::scalable_allocator<CGAL::Triangulation_cell_base_with_info_3<unsigned int, CGAL::Epick, CGAL::Triangulation_cell_base_3<CGAL::Epick, CGAL::Triangulation_ds_cell_base_3<CGAL::Triangulation_data_structure_3<CGAL::Triangulation_vertex_base_with_info_3<unsigned int, CGAL::Epick, CGAL::Triangulation_vertex_base_3<CGAL::Epick, CGAL::Triangulation_ds_vertex_base_3<void> > >, CGAL::Triangulation_cell_base_with_info_3<unsigned int, CGAL::Epick, CGAL::Triangulation_cell_base_3<CGAL::Epick, CGAL::Triangulation_ds_cell_base_3<void> > >, CGAL::Parallel_tag> > > > > >::allocate_new_block(CGAL::Free_list<CGAL::Triangulation_cell_base_with_info_3<unsigned int, CGAL::Epick, CGAL::Triangulation_cell_base_3<CGAL::Epick, CGAL::Triangulation_ds_cell_base_3<CGAL::Triangulation_data_structure_3<CGAL::Triangulation_vertex_base_with_info_3<unsigned int, CGAL::Epick, CGAL::Triangulation_vertex_base_3<CGAL::Epick, CGAL::Triangulation_ds_vertex_base_3<void> > >, CGAL::Triangulation_cell_base_with_info_3<unsigned int, CGAL::Epick, CGAL::Triangulation_cell_base_3<CGAL::Epick, CGAL::Triangulation_ds_cell_base_3<void> > >, CGAL::Parallel_tag> > > >*, unsigned long, CGAL::Concurrent_compact_container<CGAL::Triangulation_cell_base_with_info_3<unsigned int, CGAL::Epick, CGAL::Triangulation_cell_base_3<CGAL::Epick, CGAL::Triangulation_ds_cell_base_3<CGAL::Triangulation_data_structure_3<CGAL::Triangulation_vertex_base_with_info_3<unsigned int, CGAL::Epick, CGAL::Triangulation_vertex_base_3<CGAL::Epick, CGAL::Triangulation_ds_vertex_base_3<void> > >, CGAL::Triangulation_cell_base_with_info_3<unsigned int, CGAL::Epick, CGAL::Triangulation_cell_base_3<CGAL::Epick, CGAL::Triangulation_ds_cell_base_3<void> > >, CGAL::Parallel_tag> > > >, tbb::scalable_allocator<CGAL::Triangulation_cell_base_with_info_3<unsigned int, CGAL::Epick, CGAL::Triangulation_cell_base_3<CGAL::Epick, CGAL::Triangulation_ds_cell_base_3<CGAL::Triangulation_data_structure_3<CGAL::Triangulation_vertex_base_with_info_3<unsigned int, CGAL::Epick, CGAL::Triangulation_vertex_base_3<CGAL::Epick, CGAL::Triangulation_ds_vertex_base_3<void> > >, CGAL::Triangulation_cell_base_with_info_3<unsigned int, CGAL::Epick, CGAL::Triangulation_cell_base_3<CGAL::Epick, CGAL::Triangulation_ds_cell_base_3<void> > >, CGAL::Parallel_tag> > > > > > >*) in S3BulkActionTest.cpp.o
Hmmm. It's found here:┌─[adam][Hapkido][±][parallel ✓][~/CDT-plusplus]
└─▪ ./build.sh
-- Targetting Ninja
-- Found Intel TBB
-- Configuring done
-- Generating done
[11/12] Linking CXX executable cdt
I enabled it in my CMakeLists.txt:
# Experimental TBB support
# TBB 4.3 compatibility fixed in CGAL 4.5.1
find_package( TBB QUIET)
if (TBB_FOUND)
include( ${TBB_USE_FILE})
list(APPEND CGAL_3RD_PARTY_LIBRARIES ${TBB_LIBRARIES})
endif()
I didn't notice the examples including anything TBB specific, did I miss something?--On Mon, Feb 2, 2015 at 12:14 AM, Marc Glisse <> wrote:On Sun, 1 Feb 2015, Adam Getchell wrote:
FAILED: : && /usr/bin/c++ -O3 -DNDEBUG -Wl,-search_paths_first -Wl,-headerpad_max_install_names-Wl,-dylib_file,/System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGL.dylib:/System/Library/Frameworks/OpenGL.fram
ework/Versions/A/Libraries/libGL.dylib CMakeFiles/cdt.dir/src/cdt.cpp.o CMakeFiles/cdt.dir/src/docopt/docopt.cpp.o -o cdt
-L/usr/local/Cellar/cgal/4.5.1/lib /usr/local/lib/libmpfr.dylib /usr/local/lib/libgmp.dylib
/usr/local/lib/libboost_thread-mt.dylib /usr/local/lib/libboost_system-mt.dylib /usr/local/Cellar/cgal/4.5.1/lib/libCGAL_Core.dylib
-Wl,-rpath,/usr/local/Cellar/cgal/4.5.1/lib && :
I don't see any mention of TBB on this line...
Marc Glisse
Adam Getchell"Invincibility is in oneself, vulnerability in the opponent." -- Sun Tzu
- [cgal-discuss] CGAL::Parallel_tag not compatible with CGAL::Triangulation_vertex_base_with_info_3, Adam Getchell, 02/02/2015
- Re: [cgal-discuss] CGAL::Parallel_tag not compatible with CGAL::Triangulation_vertex_base_with_info_3, Marc Glisse, 02/02/2015
- Re: [cgal-discuss] CGAL::Parallel_tag not compatible with CGAL::Triangulation_vertex_base_with_info_3, Adam Getchell, 02/02/2015
