Re: [cgal-discuss] CGAL::Parallel_tag not compatible with CGAL::Triangulation_vertex_base_with_info_3
- To:
- Subject: Re: [cgal-discuss] CGAL::Parallel_tag not compatible with CGAL::Triangulation_vertex_base_with_info_3
- Date: Mon, 2 Feb 2015 10:23:31 +0100 (CET)
On Mon, 2 Feb 2015, Adam Getchell wrote:
list(APPEND CGAL_3RD_PARTY_LIBRARIES ${TBB_LIBRARIES})
Notice that in the examples that use this construction, it comes before the line:
include( CGAL_CreateSingleSourceCGALProgram )
Maybe that makes a difference. Other demos use different cmake syntax, see demo/Mesh_3 for instance.
Marc Glisse
- [cgal-discuss] CGAL::Parallel_tag not compatible with CGAL::Triangulation_vertex_base_with_info_3, Adam Getchell, 02/02/2015
- Re: [cgal-discuss] CGAL::Parallel_tag not compatible with CGAL::Triangulation_vertex_base_with_info_3, Marc Glisse, 02/02/2015
- Re: [cgal-discuss] CGAL::Parallel_tag not compatible with CGAL::Triangulation_vertex_base_with_info_3, Adam Getchell, 02/02/2015
