- To:
- Subject: Re: [cgal-discuss] Pachner moves in CGAL Triangulations
- Date: Wed, 4 Feb 2015 12:52:46 -0800
David,
Thanks for the note! Mangrove TDS looks interesting!
On Tue, Feb 3, 2015 at 8:32 AM, David Canino <> wrote:
Good Morning,sorry, if you consider this message as an OT. In case, please delete this message. At the moment, I am studying and comparing the CGAL and other libraries for geometry processing, meshing, and so on. In particular, I am trying to identify what operations may be more important in any mesh database.If it may be useful, then you find dimension-independent implementations (on simplicial d-complexes, for any d) of these editing operators (direct and inverse) for all topological data structures, that are currently implemented in any plugin in the Mangrove TDS Library (http://mangrovetds.sourceforge.net). Member functions splitTopEntity and unsplitTopEntity should be of interest for your purposes and for their porting (maybe) in CGAL. I also guess that these operators should be implemented.Best regardsDavid Canino2015-02-03 17:03 GMT+01:00 Monique Teillaud <>:Hi Adam,
Thank you for the precisions. You are right, we don't have the other two.
I guess that we could/should add them...
Monique Teillaud
http://www.loria.fr/~teillaud/
INRIA Nancy - Grand Est
Institut National de Recherche en Informatique et Automatique
Le 02/02/15 18:48, Adam Getchell a écrit :
Hi Monica,
Thank you for your reply.
It looks like "flips" implements the (2,3) and its inverse, but not the
(2,6) and (4,4) moves + inverses.
Thank you!
On Mon, Feb 2, 2015 at 1:07 AM, Monique Teillaud
< <mailto:Monique.Teillaud@inria.fr>> wrote:
Hi,
Look for "flips" in
http://doc.cgal.org/latest/__TDS_3/__classTriangulationDataStructur__e__3.html
<http://doc.cgal.org/latest/TDS_3/classTriangulationDataStructure__3.html>
If it does not provide everything you need, we could add more in CGAL.
Best,
Monique Teillaud
Le 02/02/15 02:27, Adam Getchell a écrit :
Hello all,
Before I start implementing my own version, are there Pachner moves
defined in CGAL for triangulations?
Pachner, Udo. “P.L. Homeomorphic Manifolds Are Equivalent by
Elementary
Shellings.” /European Journal of Combinatorics/ 12, no. 2 (March
1991):
129–45. doi:10.1016/S0195-6698(13)__80080-7.
Thanks,
Adam Getchell
about.me/adamgetchell <http://about.me/adamgetchell>
"Invincibility is in oneself, vulnerability in the opponent." --
Sun Tzu
https://sympa.inria.fr/sympa/__info/cgal-discuss
<https://sympa.inria.fr/sympa/info/cgal-discuss>
Adam Getchell
"Invincibility is in oneself, vulnerability in the opponent." -- Sun Tzu
Adam Getchell
"Invincibility is in oneself, vulnerability in the opponent." -- Sun Tzu- [cgal-discuss] Pachner moves in CGAL Triangulations, Adam Getchell, 02/02/2015
- Re: [cgal-discuss] Pachner moves in CGAL Triangulations, Monique Teillaud, 02/02/2015
- Re: [cgal-discuss] Pachner moves in CGAL Triangulations, Adam Getchell, 02/02/2015
- Re: [cgal-discuss] Pachner moves in CGAL Triangulations, Monique Teillaud, 02/03/2015
- Re: [cgal-discuss] Pachner moves in CGAL Triangulations, David Canino, 02/03/2015
- Re: [cgal-discuss] Pachner moves in CGAL Triangulations, Adam Getchell, 02/04/2015
- Re: [cgal-discuss] Pachner moves in CGAL Triangulations, Adam Getchell, 02/06/2015
