Re: [cgal-discuss] Delaunay_triangulation_3::flip(Cell_handle c, int i) invalidates the triangulation
- To:
- Subject: Re: [cgal-discuss] Delaunay_triangulation_3::flip(Cell_handle c, int i) invalidates the triangulation
- Date: Wed, 4 Feb 2015 22:23:42 -0800
Hello all,For the following code:void make_23_move(Delaunay* D3, std::vector<Cell_handle>* three_one,std::vector<Cell_handle>* two_two) {// Pick a random (2,2)unsigned choice = generate_random_unsigned(three_one->size());std::cout << "We're picking (3,1) vector " << choice << std::endl;Cell_handle to_be_moved = (*three_one)[choice];for (size_t i = 0; i < 4; i++) {if (D3->flip(to_be_moved, i)) {// Delaunay::flip_flippable(to_be_moved,0)std::cout << "Facet " << i << " was flippable." << std::endl;break;} else {std::cout << "Facet " << i << " was not flippable." << std::endl;}}}Invoked in the test:TEST_F(S3ErgodicMoves, MakeA23Move) {unsigned number_of_vertices_before = T.number_of_vertices();unsigned N3_31_before = three_one.size();unsigned N3_22_before = two_two.size();unsigned N3_13_before = one_three.size();std::cout << "Number of (2,2) simplices before = " << N3_22_before<< std::endl;make_23_move(&T, &three_one, &two_two);// Now look at changesreclassify_3_simplices(&T, &three_one, &two_two, &one_three);unsigned N3_31_after = three_one.size();unsigned N3_22_after = two_two.size();unsigned N3_13_after = one_three.size();EXPECT_TRUE(T.is_valid())<< "Triangulation is invalid.";I've run these tests a couple dozen times, and every time there is a flippable edge the triangulation is invalidated, e.g.:Repeating all tests (iteration 9) . . .
Note: Google Test filter = S3ErgodicMoves.MakeA23Move
[==========] Running 1 test from 1 test case.
[----------] Global test environment set-up.
[----------] 1 test from S3ErgodicMoves
[ RUN ] S3ErgodicMoves.MakeA23Move
Generating universe ...
Pass #1
Fixing foliation....
Pass #2
Pass #3
Pass #4
Pass #5
Classifying simplices....
Valid foliation: true
Delaunay triangulation has 95251 cells.
There are 29713 (3,1) simplices and 35628 (2,2) simplices and 29910 (1,3) simplices.
Number of (2,2) simplices before = 35628
Random number is 27858
We're picking (3,1) vector 27858
Facet 0 was flippable.
../unittests/S3ErgodicMovesTest.cpp:82: Failure
Value of: T.is_valid()
Actual: false
Expected: true
[ FAILED ] S3ErgodicMoves.MakeA23Move (2229 ms)
[----------] 1 test from S3ErgodicMoves (2229 ms total)
[----------] Global test environment tear-down
[==========] 1 test from 1 test case ran. (2229 ms total)
[ PASSED ] 0 tests.
[ FAILED ] 1 test, listed below:
1 FAILED TEST
--Adam Getchell"Invincibility is in oneself, vulnerability in the opponent." -- Sun Tzu
- [cgal-discuss] Delaunay_triangulation_3::flip(Cell_handle c, int i) invalidates the triangulation, Adam Getchell, 02/05/2015
- Re: [cgal-discuss] Delaunay_triangulation_3::flip(Cell_handle c, int i) invalidates the triangulation, Adam Getchell, 02/05/2015
- Re: [cgal-discuss] Delaunay_triangulation_3::flip(Cell_handle c, int i) invalidates the triangulation, Sebastien Loriot (GeometryFactory), 02/05/2015
- Re: [cgal-discuss] Delaunay_triangulation_3::flip(Cell_handle c, int i) invalidates the triangulation, Adam Getchell, 02/06/2015
- Re: [cgal-discuss] Delaunay_triangulation_3::flip(Cell_handle c, int i) invalidates the triangulation, Adam Getchell, 02/10/2015
- Re: [cgal-discuss] Delaunay_triangulation_3::flip(Cell_handle c, int i) invalidates the triangulation, Sebastien Loriot (GeometryFactory), 02/10/2015
- Re: [cgal-discuss] Delaunay_triangulation_3::flip(Cell_handle c, int i) invalidates the triangulation, Olivier Devillers, 02/10/2015
