cgal-discuss - Re: [cgal-discuss] Delaunay_triangulation_3::flip(Cell_handle c, int i) invalidates the triangulation
  • To:
  • Subject: Re: [cgal-discuss] Delaunay_triangulation_3::flip(Cell_handle c, int i) invalidates the triangulation
  • Date: Tue, 10 Feb 2015 08:37:17 +0100
On 02/10/2015 08:34 AM, Adam Getchell wrote:
Is there a way to rebalance a Delaunay triangulation after a flip() on a
facet?
what do you mean?
Sebastien.
On Fri, Feb 6, 2015 at 12:23 PM, Adam Getchell
<mailto:>>
wrote:
Sebastien,
Thank you!
In hindsight, it makes sense that the facet flip results in an edge
which violates the Delaunay condition.
Regards,
Adam
On Wed, Feb 4, 2015 at 11:32 PM, Sebastien Loriot (GeometryFactory)
<mailto:>>
wrote:
If you flip some edges in a Delaunay triangulation, the is_valid
will tell you that the triangulation is no longer Delaunay.
Use the dt.tds().is_valid() instead.
Sebastien.
On 02/05/2015 07:23 AM, Adam Getchell wrote:
I've also done tests on flips of (2,2) simplices, with the
same results
(triangulation validity violated), except that they don't
also violate
my time foliation. The code currently on GitHub reflects the
flips on
(2,2) simplices.
On Wed, Feb 4, 2015 at 10:07 PM, Adam Getchell
<mailto:>
<mailto:>>>
wrote:
Hello all,
For the following code:
void make_23_move(Delaunay* D3,
std::vector<Cell_handle>* three_one,
std::vector<Cell_handle>* two_two) {
// Pick a random (2,2)
unsigned choice =
generate_random_unsigned(__three_one->size());
std::cout << "We're picking (3,1) vector " << choice
<< std::endl;
Cell_handle to_be_moved = (*three_one)[choice];
for (size_t i = 0; i < 4; i++) {
if (D3->flip(to_be_moved, i)) {
// Delaunay::flip_flippable(to___be_moved,0)
std::cout << "Facet " << i << " was flippable."
<< std::endl;
break;
} else {
std::cout << "Facet " << i << " was not
flippable." << std::endl;
https://github.com/acgetchell/__CDT-plusplus/blob/master/src/__S3ErgodicMoves.h
<https://github.com/acgetchell/CDT-plusplus/blob/master/src/S3ErgodicMoves.h>
Invoked in the test:
TEST_F(S3ErgodicMoves, MakeA23Move) {
unsigned number_of_vertices_before =
T.number_of_vertices();
unsigned N3_31_before = three_one.size();
unsigned N3_22_before = two_two.size();
unsigned N3_13_before = one_three.size();
std::cout << "Number of (2,2) simplices before = "
<< N3_22_before
<< std::endl;
make_23_move(&T, &three_one, &two_two);
// Now look at changes
reclassify_3_simplices(&T, &three_one, &two_two,
&one_three);
unsigned N3_31_after = three_one.size();
unsigned N3_22_after = two_two.size();
unsigned N3_13_after = one_three.size();
EXPECT_TRUE(T.is_valid())
<< "Triangulation is invalid.";
https://github.com/acgetchell/__CDT-plusplus/blob/master/__unittests/S3ErgodicMovesTest.__cpp
<https://github.com/acgetchell/CDT-plusplus/blob/master/unittests/S3ErgodicMovesTest.cpp>
I've run these tests a couple dozen times, and every
time there is a
flippable edge the triangulation is invalidated, e.g.:
Repeating all tests (iteration 9) . . .
Note: Google Test filter = S3ErgodicMoves.MakeA23Move
[==========] Running 1 test from 1 test case.
[----------] Global test environment set-up.
[----------] 1 test from S3ErgodicMoves
[ RUN ] S3ErgodicMoves.MakeA23Move
Generating universe ...
Pass #1
Fixing foliation....
Pass #2
Pass #3
Pass #4
Pass #5
Classifying simplices....
Valid foliation: true
Delaunay triangulation has 95251 cells.
There are 29713 (3,1) simplices and 35628 (2,2)
simplices and 29910
(1,3) simplices.
Number of (2,2) simplices before = 35628
Random number is 27858
We're picking (3,1) vector 27858
Facet 0 was flippable.
../unittests/__S3ErgodicMovesTest.cpp:82: Failure
Value of: T.is_valid()
Actual: false
Expected: true
[ FAILED ] S3ErgodicMoves.MakeA23Move (2229 ms)
[----------] 1 test from S3ErgodicMoves (2229 ms total)
[----------] Global test environment tear-down
[==========] 1 test from 1 test case ran. (2229 ms total)
[ PASSED ] 0 tests.
[ FAILED ] 1 test, listed below:
1 FAILED TEST
Adam Getchell
about.me/adamgetchell <http://about.me/adamgetchell>
"Invincibility is in oneself, vulnerability in the
opponent." -- Sun Tzu
Adam Getchell
https://sympa.inria.fr/sympa/__info/cgal-discuss
<https://sympa.inria.fr/sympa/info/cgal-discuss>
Adam Getchell
"Invincibility is in oneself, vulnerability in the opponent." -- Sun Tzu
Adam Getchell
