Re: [cgal-discuss] import_from_triangulation_3: Issue in number of vertices stored in cell complex
- To:
- Subject: Re: [cgal-discuss] import_from_triangulation_3: Issue in number of vertices stored in cell complex
- Date: Wed, 25 Mar 2015 11:25:20 +0100
Le 25/03/15 10:34, Pranav a écrit :
Olivier Devillers-2 wrote
You did not read the documentation about the infinite vertexThanks for pointing this out. I checked and found that (0, 0, 0) is the
representation for infinite vertex.
be careful that the Point inside the infinite_vertex is uninitialized.
It is not guarantee to be 0,0,0.
I do not know really LCC, but it seems that it is for an embedded
linear cell complex. It does not seems that it uses an infinite vertex.
- [cgal-discuss] import_from_triangulation_3: Issue in number of vertices stored in cell complex, Pranav, 03/24/2015
- Re: [cgal-discuss] import_from_triangulation_3: Issue in number of vertices stored in cell complex, Olivier Devillers, 03/24/2015
- Re: [cgal-discuss] import_from_triangulation_3: Issue in number of vertices stored in cell complex, Pranav, 03/25/2015
- Re: [cgal-discuss] import_from_triangulation_3: Issue in number of vertices stored in cell complex, Olivier Devillers, 03/25/2015
- Re: [cgal-discuss] import_from_triangulation_3: Issue in number of vertices stored in cell complex, Guillaume Damiand, 03/25/2015
- Re: [cgal-discuss] import_from_triangulation_3: Issue in number of vertices stored in cell complex, Pranav, 03/27/2015
- Re: [cgal-discuss] import_from_triangulation_3: Issue in number of vertices stored in cell complex, Guillaume Damiand, 03/27/2015
