Re: [cgal-discuss] import_from_triangulation_3: Issue in number of vertices stored in cell complex
- To:
- Subject: Re: [cgal-discuss] import_from_triangulation_3: Issue in number of vertices stored in cell complex
- Date: Fri, 27 Mar 2015 04:45:33 -0700 (PDT)
Guillaume Damiand wrote
> When you call the function CGAL::import_from_triangulation_3, you can
> use an undocumented third parameter (a std::map
> std::map<Triangulation::Cell_handle, LCC_3::Dart_handle >) linking
> cells
> of the T3 and darts of the LCC.
> With this map, you can know if a dart belong to the infinite vertex of
> the T3 or not.
Since import_from_triangulation_3 returns Dart_handle to the /infinite
vertex/, I tried using it to separate out infinite vertex from other
vertices. But in this code
<https://gist.github.com/pranavkantgaur/9e928dc3fd5816cb891a#file-lccimport-cpp>
I find that the coordinates of infinite vertex in Linear cell complex are
different from those in Delaunay triangulation. Is it really a bug or I am
understanding it incorrectly?
View this message in context:
http://cgal-discuss.949826.n4.nabble.com/import-from-triangulation-3-Issue-in-number-of-vertices-stored-in-cell-complex-tp4660599p4660607.html
- [cgal-discuss] import_from_triangulation_3: Issue in number of vertices stored in cell complex, Pranav, 03/24/2015
- Re: [cgal-discuss] import_from_triangulation_3: Issue in number of vertices stored in cell complex, Olivier Devillers, 03/24/2015
- Re: [cgal-discuss] import_from_triangulation_3: Issue in number of vertices stored in cell complex, Pranav, 03/25/2015
- Re: [cgal-discuss] import_from_triangulation_3: Issue in number of vertices stored in cell complex, Olivier Devillers, 03/25/2015
- Re: [cgal-discuss] import_from_triangulation_3: Issue in number of vertices stored in cell complex, Guillaume Damiand, 03/25/2015
- Re: [cgal-discuss] import_from_triangulation_3: Issue in number of vertices stored in cell complex, Pranav, 03/27/2015
- Re: [cgal-discuss] import_from_triangulation_3: Issue in number of vertices stored in cell complex, Guillaume Damiand, 03/27/2015
