Re: [cgal-discuss] import_from_triangulation_3: Issue in number of vertices stored in cell complex
- To:
- Subject: Re: [cgal-discuss] import_from_triangulation_3: Issue in number of vertices stored in cell complex
- Date: Mon, 30 Mar 2015 01:42:29 -0700 (PDT)
Guillaume Damiand wrote
> As said by Oliviers, infinite vertex has no coordinates; thus you must
> not use that !
In that code, I have not used coordinates but I have tried to differentiate
infinite vertex from finite vertices by assigning 0 as attribute to finite
vertices and 1 as attribute to infinite vertex.
Issue is that when I try to print coordinates of finite vertices I find that
some coordinates are missing. For example in the code I find that point (1,
1, 0) is missing from finite vertices which was there in the corresponding
Delaunay triangulation.
View this message in context:
http://cgal-discuss.949826.n4.nabble.com/import-from-triangulation-3-Issue-in-number-of-vertices-stored-in-cell-complex-tp4660599p4660610.html
- [cgal-discuss] import_from_triangulation_3: Issue in number of vertices stored in cell complex, Pranav, 03/24/2015
- Re: [cgal-discuss] import_from_triangulation_3: Issue in number of vertices stored in cell complex, Olivier Devillers, 03/24/2015
- Re: [cgal-discuss] import_from_triangulation_3: Issue in number of vertices stored in cell complex, Pranav, 03/25/2015
- Re: [cgal-discuss] import_from_triangulation_3: Issue in number of vertices stored in cell complex, Olivier Devillers, 03/25/2015
- Re: [cgal-discuss] import_from_triangulation_3: Issue in number of vertices stored in cell complex, Guillaume Damiand, 03/25/2015
- Re: [cgal-discuss] import_from_triangulation_3: Issue in number of vertices stored in cell complex, Pranav, 03/27/2015
- Re: [cgal-discuss] import_from_triangulation_3: Issue in number of vertices stored in cell complex, Guillaume Damiand, 03/27/2015
- Re: [cgal-discuss] import_from_triangulation_3: Issue in number of vertices stored in cell complex, Pranav, 03/30/2015
