Re: [cgal-discuss] CGAL_triangulation_precondition vs. CGAL_triangulation_expensive_precondition
- To:
- Subject: Re: [cgal-discuss] CGAL_triangulation_precondition vs. CGAL_triangulation_expensive_precondition
- Date: Mon, 27 Apr 2015 07:30:15 -0700 (PDT)
Hi brYang,
How do you draw the cells ? or like the code show below:
Delaunay_triangulation::finite_face_iterator
begin=DT.finite_facets_begin(),end=finite_facets_end();
for(;begin!=end;++begin){
Delaunay_triangulation::Cell_handle
cell_handle=(*begin).first;
int index=(*begin).second;
int i=(index+1)&3,j=(index+2)&3,k=(index+3)&3;
std::cout<<cell_handle->vertex(i)->point()<<","\
<<cell_handle->vertex(j)->point()<<","\
<<cell_handle->vertex(k)->point()<<std::endl;
Maybe the code draw triangulation data struct is incorrect, because Delaunay
triangulation algorithm is stable,
try to find out is there some wrong with your code;
BR
TobeYang
View this message in context:
http://cgal-discuss.949826.n4.nabble.com/CGAL-triangulation-precondition-vs-CGAL-triangulation-expensive-precondition-tp4660727p4660732.html
- [cgal-discuss] CGAL_triangulation_precondition vs. CGAL_triangulation_expensive_precondition, Adam Getchell, 04/25/2015
- Re: [cgal-discuss] CGAL_triangulation_precondition vs. CGAL_triangulation_expensive_precondition, brYang, 04/27/2015
- Re: [cgal-discuss] CGAL_triangulation_precondition vs. CGAL_triangulation_expensive_precondition, TableYoung, 04/27/2015
- Re: [cgal-discuss] CGAL_triangulation_precondition vs. CGAL_triangulation_expensive_precondition, TableYoung, 04/28/2015
- Re: [cgal-discuss] CGAL_triangulation_precondition vs. CGAL_triangulation_expensive_precondition, brYang, 04/28/2015
- Re: [cgal-discuss] CGAL_triangulation_precondition vs. CGAL_triangulation_expensive_precondition, BRYang, 04/29/2015
- Re: [cgal-discuss] CGAL_triangulation_precondition vs. CGAL_triangulation_expensive_precondition, TableYoung, 04/30/2015
