Re: [cgal-discuss] CGAL_triangulation_precondition vs. CGAL_triangulation_expensive_precondition
- To:
- Subject: Re: [cgal-discuss] CGAL_triangulation_precondition vs. CGAL_triangulation_expensive_precondition
- Date: Wed, 29 Apr 2015 17:48:33 -0700 (PDT)
yes, I check the mininum dihedral angle of each cell and it seems that there
are so many slivers generated from delaunay triangulation, it could be the
limitation of DT. Any way, thank you so much for your patience.
Best regards,
Baorong Yang
View this message in context:
http://cgal-discuss.949826.n4.nabble.com/CGAL-triangulation-precondition-vs-CGAL-triangulation-expensive-precondition-tp4660727p4660772.html
- Re: [cgal-discuss] CGAL_triangulation_precondition vs. CGAL_triangulation_expensive_precondition, (continued)
- Re: [cgal-discuss] CGAL_triangulation_precondition vs. CGAL_triangulation_expensive_precondition, brYang, 04/27/2015
- Re: [cgal-discuss] CGAL_triangulation_precondition vs. CGAL_triangulation_expensive_precondition, TableYoung, 04/27/2015
- Re: [cgal-discuss] CGAL_triangulation_precondition vs. CGAL_triangulation_expensive_precondition, TableYoung, 04/28/2015
- Re: [cgal-discuss] CGAL_triangulation_precondition vs. CGAL_triangulation_expensive_precondition, brYang, 04/28/2015
- Re: [cgal-discuss] CGAL_triangulation_precondition vs. CGAL_triangulation_expensive_precondition, BRYang, 04/29/2015
- Re: [cgal-discuss] CGAL_triangulation_precondition vs. CGAL_triangulation_expensive_precondition, TableYoung, 04/30/2015
- Re: [cgal-discuss] CGAL_triangulation_precondition vs. CGAL_triangulation_expensive_precondition, BRYang, 04/30/2015
- Re: [cgal-discuss] CGAL_triangulation_precondition vs.CGAL_triangulation_expensive_precondition, JacaYang, 04/30/2015
- Re: [cgal-discuss] CGAL_triangulation_precondition vs. CGAL_triangulation_expensive_precondition, Monique Teillaud, 04/27/2015
- Re: [cgal-discuss] CGAL_triangulation_precondition vs. CGAL_triangulation_expensive_precondition, Adam Getchell, 04/27/2015
