- To: "" <>
- Subject: [cgal-discuss] error in cgal compileing
- Date: Mon, 27 Apr 2015 19:14:31 +0000 (UTC)
hi sir,
i had installed CGAL 4.6 and its components successfully by using CMake
i use CodeBlock IDE to compile the given examples in CGAL folder.
But there are error in direcoty
and some time error in header file
how to solve this problem
note
what i should use the source code file or the place where build the binaries
thanks
Description: PNG image
AABB_custom_example.cpp - Code::Blocks 13.12_003.png
AABB_custom_indexed_triangle_set_array_example.cpp - Code::Blocks 13.12_004.png
- [cgal-discuss] error in cgal compileing, Medhat Rashad, 04/27/2015
- Re: [cgal-discuss] error in cgal compileing, Joachim Reichel, 04/28/2015
- Re: [cgal-discuss] error in cgal compileing, Medhat Rashad, 04/29/2015
