- To: cgal-discuss <>
- Subject: Re: [cgal-discuss] Slicing/splitting/cutting polyhedral meshes
- Date: Thu, 30 Apr 2015 15:45:00 -0400
Hey guys,
To do that, I've changed all Vertex() constructors from halfedgeDS_cut_component to Vertex(pred.getPlane().projection(h->vertex()->point())). I've also made some few adjustments on the polyhedron_cut_plane_3. If anyone is interested I can post the full modified code.
Vinicius C. Azevedo.
On Thu, Apr 30, 2015 at 2:02 PM, Vinicius Azevedo <> wrote:
Update:The polyhedron_cut_plane_3 function calls I_polyhedron_cut_component( poly, h, pred) routine. This returns a set of invalid (uninitialized?) edges/faces that are connected to the newly created cut border.Vinicius C. Azevedo.On Wed, Apr 29, 2015 at 2:48 PM, Vinicius Azevedo <> wrote:OK, so I think that I found a potential problem. Inside the polyhedron_cut_plane_3 function we have:
Halfedge_handle start = h;do {h->vertex()->point() = construct_point( plane, h->next()->opposite()->facet()->plane(), h->opposite()->facet()->plane());h = h->next();} while ( h != start);
This function basically computes the intersection point from 3 planes: the cutting plane and the two planes that pass through the current edge. The function construct_point is:operator()( const Plane_3& p, const Plane_3& q, const Plane_3& r) const {Object obj = intersection( p, q);Line_3 line;if ( assign( line, obj)) {obj = intersection( r, line);Point_3 pt;if ( assign( pt, obj)) {return pt;}}std::cerr << "ERROR: coplanar planes used for computing " "intersecting point." << std::endl;std::cerr << " Return ORIGIN. Don't trust result." << std::endl;return ORIGIN;}
This function tries to find the intersection point by successively computing intersections between the planes. But this algorithm will fail if r and q planes are colinear. That means that if an edge has two colinear planes (e.g. a simple plane), that algorithm will not work. So perhaps a function that better computes the intersection between a plane and an edge has to be used to solved this problem.Any ideas? Is what I said correct?Vinicius.Vinicius C. Azevedo.On Wed, Apr 29, 2015 at 11:15 AM, Vinicius Azevedo <> wrote:Sure, here's the code snippet: http://pastebin.com/C892FnCuThe interesting thing though is that the halfedge handle that I'm passing is not one that directly crosses the polyline intersection.If I try to pass an edge that is being actually intersected by the polyline I get an assertion error.Vinicius C. Azevedo.On Wed, Apr 29, 2015 at 11:01 AM, Sebastien Loriot (GeometryFactory) <> wrote:On 04/29/2015 04:56 PM, Vinicius Azevedo wrote:
I was confused by the cut/slice examples on the Polyhedron demo. II think so.
thought you was mentioning that, my bad. That's what I was looking for,
thanks! I have some questions though on how to use this function:
* What should I pass to the function as starting halfedge? Is it an
edge returned by any_intersection?
* Does this function add vertices from the polyline that is generatedI never used the function. Could you share your code so that I can
from the intersection of the polyhedron with the plane? That's not
what I'm getting on my results
(https://dl.dropboxusercontent.com/u/5919734/bunnyCut1.png &&
https://dl.dropboxusercontent.com/u/5919734/bunnyCut2.png). It only
cuts the mesh by following pre-existent vertices. Also I'm having
the error "coplanar planes used for computing the intersection
plane, Return ORIGIN, Don't trust the result".
give it a try?
Sebastien.
Thanks for your help so far!
On Tue, Apr 28, 2015 at 10:24 AM, Sebastien Loriot (GeometryFactory)< <mailto:>> wrote:
On 04/28/2015 02:15 PM, Vinicius Azevedo wrote:
Hi Sebastian,
Thanks for your answer. I didn't expressed myself so well. What
I want
is to actually cut the mesh into two different independent parts
with a
given cut plane. In this video
https://www.youtube.com/watch?v=IOnk7PBv1AU and paper
http://www.math.ucla.edu/~jteran/papers/WJST14.pdf, they present
some
techniques to do that robustly. I saw the examples that you
mentioned,
and it seems that they only compute the intersections of planes and
Polyhedrons, but don't actually split it into different parts.
I believe this is what polyhedron_cut_plane_3.h is doing. The comment
for this function is:
// Cuts the polyhedron `poly' at plane `plane' starting at halfedge `h'.
// Traces the intersection curve of `plane' with `poly' starting at `h',
// cuts `poly' along that intersection curve and deletes the (connected)
// component on the negative side of the plane. The hole created along
// the intersection curve is filled with a new face containing the plane
// and the points in the vertices are computed.
Sebastien.
On Tue, Apr 28, 2015 at 1:48 AM, Sebastien Loriot (GeometryFactory)
< <mailto:><mailto: <mailto:>>> wrote:
On 04/27/2015 04:31 PM, Vinicius Azevedo wrote:
Hi all,
I would like to know if anyone has a code snippet for
slicing/splitting/cutting polyhedral meshes in two
different
parts with
arbitrary planes. I've seen some old threads about it
(http://cgal-discuss.949826.n4.nabble.com/Slices-in-a-mesh-td951695.html),
but didn't find any code examples so far.
Thanks!
The thread you mention is to compute the intersection of a
polyhedron
with a plane which is one or several polygons. There is a
non documented
functor that is doing this in CGAL/Polyhedron_slicer_3.h
A better and documented version will be included in CGAL 4.8
In your case, it seems you want the intersection of a
polyhedron with
a halfspace.
There is another documented function
'CGAL::polyhedron_cut_plane_3'
I never used that is defined in CGAL/polyhedron_cut_plane_3.h
that should be doing what you want.
Sebastien.
- [cgal-discuss] Slicing/splitting/cutting polyhedral meshes, Vinicius Azevedo, 04/27/2015
- Re: [cgal-discuss] Slicing/splitting/cutting polyhedral meshes, Sebastien Loriot (GeometryFactory), 04/28/2015
- Re: [cgal-discuss] Slicing/splitting/cutting polyhedral meshes, Vinicius Azevedo, 04/28/2015
- Re: [cgal-discuss] Slicing/splitting/cutting polyhedral meshes, Vinicius Azevedo, 04/29/2015
- Re: [cgal-discuss] Slicing/splitting/cutting polyhedral meshes, Sebastien Loriot (GeometryFactory), 04/29/2015
- Re: [cgal-discuss] Slicing/splitting/cutting polyhedral meshes, Vinicius Azevedo, 04/30/2015
