cgal-discuss - Re: [cgal-discuss] Slicing/splitting/cutting polyhedral meshes
  • To:
  • Subject: Re: [cgal-discuss] Slicing/splitting/cutting polyhedral meshes
  • Date: Wed, 29 Apr 2015 17:01:04 +0200
On 04/29/2015 04:56 PM, Vinicius Azevedo wrote:
I was confused by the cut/slice examples on the Polyhedron demo. I
thought you was mentioning that, my bad. That's what I was looking for,
thanks! I have some questions though on how to use this function:
* What should I pass to the function as starting halfedge? Is it an
edge returned by any_intersection?
I think so.
* Does this function add vertices from the polyline that is generated
from the intersection of the polyhedron with the plane? That's not
what I'm getting on my results
(https://dl.dropboxusercontent.com/u/5919734/bunnyCut1.png &&
https://dl.dropboxusercontent.com/u/5919734/bunnyCut2.png). It only
cuts the mesh by following pre-existent vertices. Also I'm having
the error "coplanar planes used for computing the intersection
plane, Return ORIGIN, Don't trust the result".
I never used the function. Could you share your code so that I can
give it a try?
Sebastien.
Thanks for your help so far!
Vinicius C. Azevedo.
On Tue, Apr 28, 2015 at 10:24 AM, Sebastien Loriot (GeometryFactory)
<mailto:>>
wrote:
On 04/28/2015 02:15 PM, Vinicius Azevedo wrote:
Hi Sebastian,
Thanks for your answer. I didn't expressed myself so well. What
I want
is to actually cut the mesh into two different independent parts
with a
given cut plane. In this video
https://www.youtube.com/watch?v=IOnk7PBv1AU and paper
http://www.math.ucla.edu/~jteran/papers/WJST14.pdf, they present
some
techniques to do that robustly. I saw the examples that you
mentioned,
and it seems that they only compute the intersections of planes and
Polyhedrons, but don't actually split it into different parts.
I believe this is what polyhedron_cut_plane_3.h is doing. The comment
for this function is:
// Cuts the polyhedron `poly' at plane `plane' starting at halfedge `h'.
// Traces the intersection curve of `plane' with `poly' starting at `h',
// cuts `poly' along that intersection curve and deletes the (connected)
// component on the negative side of the plane. The hole created along
// the intersection curve is filled with a new face containing the plane
// and the points in the vertices are computed.
Sebastien.
On Tue, Apr 28, 2015 at 1:48 AM, Sebastien Loriot (GeometryFactory)
<mailto:>
<mailto:
<mailto:>>>
wrote:
On 04/27/2015 04:31 PM, Vinicius Azevedo wrote:
Hi all,
I would like to know if anyone has a code snippet for
slicing/splitting/cutting polyhedral meshes in two
different
parts with
arbitrary planes. I've seen some old threads about it
(http://cgal-discuss.949826.n4.nabble.com/Slices-in-a-mesh-td951695.html),
but didn't find any code examples so far.
Thanks!
The thread you mention is to compute the intersection of a
polyhedron
with a plane which is one or several polygons. There is a
non documented
functor that is doing this in CGAL/Polyhedron_slicer_3.h
A better and documented version will be included in CGAL 4.8
In your case, it seems you want the intersection of a
polyhedron with
a halfspace.
There is another documented function
'CGAL::polyhedron_cut_plane_3'
I never used that is defined in CGAL/polyhedron_cut_plane_3.h
that should be doing what you want.
Sebastien.
