cgal-discuss - Re: [cgal-discuss] Slicing/splitting/cutting polyhedral meshes
  • To: cgal-discuss <>
  • Subject: Re: [cgal-discuss] Slicing/splitting/cutting polyhedral meshes
  • Date: Wed, 29 Apr 2015 11:15:46 -0400
Sure, here's the code snippet: http://pastebin.com/C892FnCu
The interesting thing though is that the halfedge handle that I'm passing is not one that directly crosses the polyline intersection.If I try to pass an edge that is being actually intersected by the polyline I get an assertion error.
Vinicius C. Azevedo.
On Wed, Apr 29, 2015 at 11:01 AM, Sebastien Loriot (GeometryFactory) <> wrote:
On 04/29/2015 04:56 PM, Vinicius Azevedo wrote:
I was confused by the cut/slice examples on the Polyhedron demo. I
thought you was mentioning that, my bad. That's what I was looking for,
thanks! I have some questions though on how to use this function:
  * What should I pass to the function as starting halfedge? Is it an
    edge returned by any_intersection?
I think so.
  * Does this function add vertices from the polyline that is generated
    from the intersection of the polyhedron with the plane? That's not
    what I'm getting on my results
    (https://dl.dropboxusercontent.com/u/5919734/bunnyCut1.png &&
    https://dl.dropboxusercontent.com/u/5919734/bunnyCut2.png). It only
    cuts the mesh by following pre-existent vertices. Also I'm having
    the error "coplanar planes used for computing the intersection
    plane, Return ORIGIN, Don't trust the result".
I never used the function. Could you share your code so that I can
give it a try?
Sebastien.
Thanks for your help so far!
On Tue, Apr 28, 2015 at 10:24 AM, Sebastien Loriot (GeometryFactory)
< <mailto:>> wrote:
    On 04/28/2015 02:15 PM, Vinicius Azevedo wrote:
        Hi Sebastian,
        Thanks for your answer. I didn't expressed myself so well. What
        I want
        is to actually cut the mesh into two different independent parts
        with a
        given cut plane. In this video
        https://www.youtube.com/watch?v=IOnk7PBv1AU and paper
        http://www.math.ucla.edu/~jteran/papers/WJST14.pdf, they present
        some
        techniques to do that robustly. I saw the examples that you
        mentioned,
        and it seems that they only compute the intersections of planes and
        Polyhedrons, but don't actually split it into different parts.
    I believe this is what polyhedron_cut_plane_3.h is doing. The comment
    for this function is:
    // Cuts the polyhedron `poly' at plane `plane' starting at halfedge `h'.
    // Traces the intersection curve of `plane' with `poly' starting at `h',
    // cuts `poly' along that intersection curve and deletes the (connected)
    // component on the negative side of the plane. The hole created along
    // the intersection curve is filled with a new face containing the plane
    // and the points in the vertices are computed.
    Sebastien.
        On Tue, Apr 28, 2015 at 1:48 AM, Sebastien Loriot (GeometryFactory)
        < <mailto:>
        <mailto: <mailto:>>> wrote:
             On 04/27/2015 04:31 PM, Vinicius Azevedo wrote:
                 Hi all,
                 I would like to know if anyone has a code snippet for
                 slicing/splitting/cutting polyhedral meshes in two
        different
                 parts with
                 arbitrary planes. I've seen some old threads about it
        (http://cgal-discuss.949826.n4.nabble.com/Slices-in-a-mesh-td951695.html),
                 but didn't find any code examples so far.
                 Thanks!
             The thread you mention is to compute the intersection of a
        polyhedron
             with a plane which is one or several polygons. There is a
        non documented
             functor that is doing this in CGAL/Polyhedron_slicer_3.h
             A better and documented version will be included in CGAL 4.8
             In your case, it seems you want the intersection of a
        polyhedron with
             a halfspace.
             There is another documented function
        'CGAL::polyhedron_cut_plane_3'
             I never used that is defined in CGAL/polyhedron_cut_plane_3.h
             that should be doing what you want.
             Sebastien.
