cgal-discuss - Re: [cgal-discuss] write out and read in (Delauney) triangulation
  • To:
  • Subject: Re: [cgal-discuss] write out and read in (Delauney) triangulation
  • Date: Mon, 11 May 2015 19:14:21 +0200
Le 08/05/15 17:27, Tom Van Doorsselaere a écrit :
Dear CGAL enthousiasts,
Dear Tom,
I'm building a program for the rendering of emission of solar coronal
models.
This sounds very interesting.
I tested your code on my laptop, with CGAL 4.6, both release and debug modes, clang 5.0.
I had to add a space line 61 to avoid the consecutive >>
vector<vector<double> > allvar;
Then it compiled.
teillaud@tzitziki:~/CGAL/test >./testreadinwriteout --write
writing out triangulationGelukt
teillaud@tzitziki:~/CGAL/test >./testreadinwriteout --read
reading in triangulationGelukt
If I understand correctly, this is the result that you expect. It seems to work like a charm...
Best regards,
Monique Teillaud
http://www.loria.fr/~teillaud/
INRIA Nancy - Grand Est, LORIA
Institut National de Recherche en Informatique et Automatique
For that I'm doing simulations first, computing the
triangulation, which I then render onto artificial images. Since it is
the bottleneck of the computation, I would like to store the
triangulation, to be read in again for the rendering stage.
I have attached a minimal representation of my code, with test data. I
have compiled the code with gcc version 4.4.7:
g++ -frounding-math -std=gnu++0x -g -Wall -lCGAL -lgmp -o testreadin
testreadinwriteout.cpp
and then run it with
./testreadin --write
and
./testreadin --read
terminate called after throwing an instance of 'CGAL::Assertion_exception'
what(): CGAL ERROR: assertion violation!
Expr: false
File: /usr/include/CGAL/Triangulation_3.h
Line: 5321
reading in triangulationAborted
I have no idea what can cause this issue, because I have checked the
validity of the triangulation in the write stage, and I would expect a
written valid triangulation to be read in again as one.
Even more confusing is that when I remove the conversion from
cylindrical coordinates in the data file to cartesian coordinates in the
code (i.e. line 82 and 83 in the attached program), then the reading in
and writing out is no issue and both stages work as expected.
What important issue am I missing here?
Thanks for your input!
Tom
