- To:
- Subject: Re: [cgal-discuss] write out and read in (Delauney) triangulation
- Date: Tue, 12 May 2015 15:39:21 +0200
As promised, I have tested the code on two computers, with different
versions of gcc (4.4.7 and 4.9.2) and with different combinations of
flags. However, I always get stuck at the assertion violation.
I have also tried CGAL version 4.3 and 4.0.2.
I have further simplified the example (so it doesn't need gnu++0x
anylonger, and fixing the space Monique pointed out). Now it compiles with
g++ -frounding-math -lCGAL -lgmp -o testreadin testreadinwriteout.cpp
but the problem persists.
After running
>> ./testreadin --write
writing out triangulationGelukt
the reading in of the triangulation fails:
>> ./testreadin --read
terminate called after throwing an instance of 'CGAL::Assertion_exception'
what(): CGAL ERROR: assertion violation!
Expr: false
File: /usr/include/CGAL/Triangulation_3.h
Line: 5330
reading in triangulationAborted
I will look into compiling CGAL with clang or icc. However, in the end,
I suppose I would like to use gcc, because it is readily available on
most systems.
Can anybody reproduce the assertion using gcc on their computer?
Thanks,
Tom
On 05/12/15 09:33, Tom Van Doorsselaere wrote:
> Dear Monique,
> Thanks for your e-mail.
> This is very interesting indeed. It thus means that
> - either it is a compiler issue,
> - or I am forgetting a compiler flag or have a flag too much.
> I will try this afternoon with different versions of gcc and with a
> combination of flags.
> Thanks for your input! I had not thought in this direction.
> Tom
> On 05/11/15 19:14, Monique Teillaud wrote:
>> Le 08/05/15 17:27, Tom Van Doorsselaere a écrit :
>>> Dear CGAL enthousiasts,
>> Dear Tom,
>>> I'm building a program for the rendering of emission of solar coronal
>>> models.
>> This sounds very interesting.
>> I tested your code on my laptop, with CGAL 4.6, both release and debug
>> modes, clang 5.0.
>> I had to add a space line 61 to avoid the consecutive >>
>> vector<vector<double> > allvar;
>> Then it compiled.
>> teillaud@tzitziki:~/CGAL/test >./testreadinwriteout --write
>> teillaud@tzitziki:~/CGAL/test >./testreadinwriteout --read
>> reading in triangulationGelukt
>> If I understand correctly, this is the result that you expect. It seems
>> to work like a charm...
>> Best regards,
#include <fstream> #include <sstream> #include <cstdlib> #include <cmath> #include <CGAL/Exact_predicates_inexact_constructions_kernel.h> #include <CGAL/Delaunay_triangulation_3.h> #include <CGAL/interpolation_functions.h> using namespace std; typedef CGAL::Exact_predicates_inexact_constructions_kernel K; typedef CGAL::Delaunay_triangulation_3<K, CGAL::Fast_location> Delaunay_triangulation_3; typedef K::Point_3 Point; Delaunay_triangulation_3 DT_global; void writetriangulation(const string snapsave, const Delaunay_triangulation_3 *DTpointer) { ofstream out(snapsave.c_str(),ios::ate|ios::trunc); if (out.is_open()) { if (DTpointer!=NULL) out << *DTpointer; out.close(); } else cout << "Unable to write to " << snapsave << endl; } void readtriangulation(const string snapsave, Delaunay_triangulation_3 *DTpointer) { ifstream in(snapsave.c_str()); if (in.is_open()) { if (!in.eof() && (DTpointer!=NULL)) { in >> *DTpointer; // Check is this is a valid Delaunay triangulation //assert(DTpointer->is_valid()); } in.close(); } } int main(int argc, char* argv[]) { stringstream ss; ss << "vae2_delta1_t=0.test2"; string filename=ss.str(); ss.str(""); ss << "emissionsave"; string snapsave=ss.str(); ss.str(""); if (strcmp(argv[1],"--write")==0) { cout << "writing out triangulation"; int dim=3; int ng = 500/2; int nvars = 5; // \rho, T, vx, vy, vz vector<double> * grid=new vector<double>[dim]; vector<vector<double> > allvar; allvar.resize(nvars); double r, theta; ifstream in(filename.c_str(),ios::binary); if (in.is_open()) { for (int i=0; i<dim; i++) { grid[i].resize(ng); } for (int i=0; i<nvars; i++) { allvar[i].resize(ng); } for (int j=0; j<ng; j++) { for (int i=0; i<dim; i++) in >> grid[i][j]; for (int i=0; i<nvars; i++) in >> allvar[i][j]; r=grid[0][j]; theta=grid[1][j]; grid[0][j]=r*cos(theta); grid[1][j]=r*sin(theta); } in.close(); } vector<Point> delaunaygrid; delaunaygrid.resize(ng); for (int i=0; i<ng; i++) { delaunaygrid[i]=Point(grid[0][i],grid[1][i],grid[2][i]); } DT_global.insert(delaunaygrid.begin(),delaunaygrid.end()); assert(DT_global.is_valid()); assert(DT_global.dimension()==3); writetriangulation(snapsave,&DT_global); } else { Delaunay_triangulation_3 DT; cout << "reading in triangulation"; readtriangulation(snapsave,&DT); assert(DT_global.is_valid()); } cout << "Gelukt\n" ; return EXIT_SUCCESS; }
- [cgal-discuss] write out and read in (Delauney) triangulation, Tom Van Doorsselaere, 05/08/2015
- Re: [cgal-discuss] write out and read in (Delauney) triangulation, Monique Teillaud, 05/11/2015
- Re: [cgal-discuss] write out and read in (Delauney) triangulation, Tom Van Doorsselaere, 05/12/2015
- Re: [cgal-discuss] write out and read in (Delauney) triangulation, Monique Teillaud, 05/12/2015
- Re: [cgal-discuss] write out and read in (Delauney) triangulation, Tom Van Doorsselaere, 05/13/2015
- Re: [cgal-discuss] write out and read in (Delauney) triangulation, Monique Teillaud, 05/13/2015
