- To:
- Subject: Re: [cgal-discuss] write out and read in (Delauney) triangulation
- Date: Tue, 12 May 2015 16:28:19 +0200
Le 12/05/15 16:15, Tom Van Doorsselaere a écrit :
I have also used the clang++ compiler and icpc compiler (for CGAL and
the demo program). For both of these compilers I get the same assertion
fault.
Monique, what versions of CGAL and clang compiler did you use?
see the email that I sent yesterday (the inclusion is still visible below)
On 05/12/15 15:39, Tom Van Doorsselaere wrote:
As promised, I have tested the code on two computers, with different
versions of gcc (4.4.7 and 4.9.2) and with different combinations of
flags. However, I always get stuck at the assertion violation.
I have also tried CGAL version 4.3 and 4.0.2.
I have further simplified the example (so it doesn't need gnu++0x
anylonger, and fixing the space Monique pointed out). Now it compiles with
g++ -frounding-math -lCGAL -lgmp -o testreadin testreadinwriteout.cpp
but the problem persists.
After running
writing out triangulationGelukt./testreadin --write
the reading in of the triangulation fails:
terminate called after throwing an instance of 'CGAL::Assertion_exception'./testreadin --read
what(): CGAL ERROR: assertion violation!
Expr: false
File: /usr/include/CGAL/Triangulation_3.h
Line: 5330
reading in triangulationAborted
I will look into compiling CGAL with clang or icc. However, in the end,
I suppose I would like to use gcc, because it is readily available on
most systems.
Can anybody reproduce the assertion using gcc on their computer?
Thanks,
Tom
On 05/12/15 09:33, Tom Van Doorsselaere wrote:
Dear Monique,
Thanks for your e-mail.
This is very interesting indeed. It thus means that
- either it is a compiler issue,
- or I am forgetting a compiler flag or have a flag too much.
I will try this afternoon with different versions of gcc and with a
combination of flags.
Thanks for your input! I had not thought in this direction.
Tom
On 05/11/15 19:14, Monique Teillaud wrote:
Le 08/05/15 17:27, Tom Van Doorsselaere a écrit :
Dear CGAL enthousiasts,
Dear Tom,
I'm building a program for the rendering of emission of solar coronal
models.
This sounds very interesting.
I tested your code on my laptop, with CGAL 4.6, both release and debug
modes, clang 5.0.
I had to add a space line 61 to avoid the consecutive >>
vector<vector<double> > allvar;
Then it compiled.
teillaud@tzitziki:~/CGAL/test >./testreadinwriteout --write
teillaud@tzitziki:~/CGAL/test >./testreadinwriteout --read
reading in triangulationGelukt
If I understand correctly, this is the result that you expect. It seems
to work like a charm...
Best regards,
Monique Teillaud
http://www.loria.fr/~teillaud/
INRIA Nancy - Grand Est, LORIA
Institut National de Recherche en Informatique et Automatique
- [cgal-discuss] write out and read in (Delauney) triangulation, Tom Van Doorsselaere, 05/08/2015
- Re: [cgal-discuss] write out and read in (Delauney) triangulation, Monique Teillaud, 05/11/2015
- Re: [cgal-discuss] write out and read in (Delauney) triangulation, Tom Van Doorsselaere, 05/12/2015
- Re: [cgal-discuss] write out and read in (Delauney) triangulation, Monique Teillaud, 05/12/2015
- Re: [cgal-discuss] write out and read in (Delauney) triangulation, Tom Van Doorsselaere, 05/13/2015
- Re: [cgal-discuss] write out and read in (Delauney) triangulation, Monique Teillaud, 05/13/2015
