- To:
- Subject: Re: [cgal-discuss] Bug with Delaunay triangulation in CGAL?
- Date: Tue, 19 May 2015 07:42:44 -0700 (PDT)
Hi,
Yes, that is what I mean: on the first system it works well from
inside/outside VS. On the second system it only works inside VS, the result
is wrong and different each time I run manually the compiled .exe file. And
I am sure that I run the correct file. If I copy that file and run it on the
first system, it works perfectly. All the input data, used libraries and
compiling settings are same on both systems.
Best and Regards.
LTH.
View this message in context:
http://cgal-discuss.949826.n4.nabble.com/Bug-with-Delaunay-triangulation-in-CGAL-tp4660840p4660846.html
- [cgal-discuss] Bug with Delaunay triangulation in CGAL?, LTH, 05/18/2015
- Re: [cgal-discuss] Bug with Delaunay triangulation in CGAL?, Vinicius Azevedo, 05/19/2015
- Re: [cgal-discuss] Bug with Delaunay triangulation in CGAL?, LTH, 05/19/2015
- Re: [cgal-discuss] Bug with Delaunay triangulation in CGAL?, Laurent Rineau (CGAL/GeometryFactory), 05/21/2015
