- To:
- Subject: Re: [cgal-discuss] CGAL::make_mesh_3 not consistent
- Date: Fri, 22 May 2015 16:07:51 +0200
Hi Sebastien
Thanks for your reply.
Sharing my code is a bit difficult, since it getting quite large (custom label mesh domain derived from Labeled_mesh_domain_3, custom facet sizing field image computed at same resolution as segmentation, etc.). To clarify: I mean the smoothness of the domain interface surfaces.
What I observed so far:
- It seems to make the domain interfaces smoother if I switch on ODT and Lloyd optimization. However, I wonder why the cropped segmentation is so much smoother, even without ODT/Lloyd optimization.
- Making the facet distance smaller does not seem to make domain interfaces smoother.
- The noisy domain interfaces occur where the mesh is finest, where I am trying to resolve thin skin-like tissue regions.
Questions:
- Could it be related perturbation/exudation (e.g. default time limits)?
- What other parameters should I try?
- Is my strategy reasonable to define a non-constant facet sizing field, and a constant cell sizing and constant facet distance? Do you have any recommendations?
- I pass a Bbox to the mesh domain? For the full body segmentation this box is long in z-direction, for the cropped region the box is nearly a cube. Could this have an influence? How are the points sampled during mesh generation?
Thanks for any suggestions!
Bryn
In general,
On 22.05.2015 11:04, Sebastien Loriot (GeometryFactory) wrote:
Could you share the code used?
It might be that you have a parameter that is depending on the bbox of the model (which would explain the smoothness when the model's bbox is
smaller).
Sebastien.
On 05/21/2015 03:00 PM, Bryn Lloyd wrote:
Hi
I am using CGAL::make_mesh_3 with CGAL::Labeled_image_mesh_domain_3 and
a sizing field for the facets.
When I generate a mesh of a full anatomical body segmentation it is very
spiky/noisy.
When I generate a mesh using the same parameters, but a subset of the
segmented image (1/4 in longest axis), the mesh is much smoother.
Why does the mesh change for exactly the same model and parameters? Has
anybody had any similar problems? What could help to improve the mesh of
the full body?
Note:
- My image has voxels with spacing 0.5, my sizing field is in the range
[0.5, 6].
- Other parameters include: Mesh_criteria criteria(facet_angle=25,
facet_size=facet_sizing_field, facet_distance=1.0,
cell_radius_edge_ratio=2.0, cell_size=Constant_sizing(6.0) );
- I run the make_mesh_3 command with default args (without ODT and Lloyd
smoothing, but with perturb/exude ON).
Any suggestions/help would be greatly appreciated.
How are the mesh points sampled or domain intersections found? Does the
bounding box (shape) of the domain/oracle have any influence?
Thanks, Bryn
- [cgal-discuss] CGAL::make_mesh_3 not consistent, Bryn Lloyd, 05/21/2015
- Re: [cgal-discuss] CGAL::make_mesh_3 not consistent, Sebastien Loriot (GeometryFactory), 05/22/2015
- Re: [cgal-discuss] CGAL::make_mesh_3 not consistent, Bryn Lloyd, 05/22/2015
