cgal-discuss - Re: [cgal-discuss] Assertion violation in refine_CGAL::Delaunay_mesh_2 using CGAL::Exact_predicates_inexact_constructions_kernel
  • To:
  • Subject: Re: [cgal-discuss] Assertion violation in refine_CGAL::Delaunay_mesh_2 using CGAL::Exact_predicates_inexact_constructions_kernel
  • Date: Sat, 23 May 2015 15:02:08 -0300
As far as I know, I can't use CGAL::refine_Delaunay_mesh_2 with EPECK. It needs _sqrt, which will consume all the memory. Am I wrong?
On Fri, May 22, 2015 at 6:33 AM, Sebastien Loriot (GeometryFactory) <> wrote:
On 05/22/2015 11:30 AM, Renato Silveira wrote:
Thank you! I will try it!
The problem with  CGAL::Exact_predicates_exact_constructions_kernel is
that the programs consumes all the memory and than crash. The problem
with points very close to each other can cause this behavior?
Note that there is no _sqrt here (which is not needed for CDT only).
Sebastien.
Thanks
On Fri, May 22, 2015 at 6:00 AM, Sebastien Loriot (GeometryFactory)
< <mailto:>> wrote:
    It might be that you have two points really close to each other
    after the self-intersection removal.
    Maybe you should first run the polyline simplification algorithm:
    http://doc.cgal.org/latest/Polyline_simplification_2/index.html#Chapter_2D_Polyline_simplification
    It would definitely help if you can share a minimal example showing
    the issue.
    For compute_subcurves, you should use
    CGAL::Exact_predicates_exact_constructions_kernel (EPECK) as Kernel.
    Note also that you can compute the self-intersection inside a CDT
    if intersection tag allows it. It will be safer to use EPECK too
    in this case.
    Sebastien.
    On 05/22/2015 09:36 AM, Renato Silveira wrote:
        Hi,
        I'm trying to refine a Deluanay triangulation using
        CGAL::refine_Delaunay_mesh_2. I'm using the kernel definitions:
        typedef CGAL::Exact_predicates_inexact_constructions_kernelK;
        typedef CGAL::Triangulation_vertex_base_2<K>Vb;
        typedef CGAL::Delaunay_mesh_face_base_2<K>Fb;
        typedef CGAL::Triangulation_data_structure_2<Vb, Fb>Tds;
        typedef CGAL::Exact_predicates_tagItag;
        typedef CGAL::Constrained_Delaunay_triangulation_2<K, Tds, Itag>CDT;
        typedef CGAL::Delaunay_mesh_size_criteria_2<CDT>Criteria;
        typedef CGAL::Delaunay_mesher_2<CDT, Criteria>Mesher;
        typedef CDT::Vertex_handleVertex_handle;
        typedef CDT::PointCDT_Point;
        Initially, my CDT constraints auto-intersects, but I eliminate
        intersections using *CGAL::compute_subcurves *(using kernel
        *CGAL::Quotient<CGAL::MP_Float>*) on the constraints before the
        triangulation, as shown in attached figure (I thought it could
        solves
        the problem).
        I got a valid CDT triangulation (as shown in the attached
        figure) but
        when I try to refine the CDT, using the method:
        *CGAL::refine_Delaunay_mesh_2(...);*
        with the criteria:
        *Criteria(0.125, 25.0f)*
        I got this assert violation:
        /*terminate called after throwing an instance of
        'CGAL::Assertion_exception' */
        /*  what():  CGAL ERROR: assertion violation! */
        /*Expr: n == zone.fh */
        /*File: /usr/local/include/CGAL/Mesh_2/Refine_edges.h */
        /*Line: 438 */
        I think constraint intersections can appear again when I convert
        points
        from kernel *CGAL::Quotient<CGAL::MP_Float>* to kernel
        *CGAL::Exact_predicates_inexact_constructions_kernel*. If I
        could run
        *CGAL::Delaunay_mesher_2* with kernel
        *CGAL::Quotient<CGAL::MP_Float>* I
        will not have any intersections (I think).
        I don't know if the problem is with my constraints or with the
        mesher.
        Any ideas what I should try?
        PS:
        - Using only the boundary as CDT constraints, everything works
        fine (as
        shown in attached figure).
        - I also tested everything with
        Exact_predicates_exact_constructions_kernel_with_sqrt kernel, with
        CGAL::Exact_intersections_tag but it takes so much time and then
        it run
        out of memory with the message: "GNU MP: Cannot allocate memory
        (size=25186388)".
        Thank you in advance
        Renato
        */Renato Silveira
               Ph.D. in Computer Science
               Informatics Institute - UFRGS
               Porto Alegre - RS - Brazil
        http://www.inf.ufrgs.br/~rsilveira
*/Renato Silveira
Renato Silveira
