- To:
- Subject: Re: [cgal-discuss] construct polyhedron from tetrahedrons.
- Date: Tue, 01 Sep 2015 10:47:42 +0200
- Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None ; spf=Pass ; spf=None
- Ironport-phdr: 9a23:nXFFpRzyW2N4ZzzXCy+O+j09IxM/srCxBDY+r6Qd0OsRIJqq85mqBkHD//Il1AaPBtWAra0fwLKJ+4nbGkU+or+5+EgYd5JNUxJXwe43pCcHRPC/NEvgMfTxZDY7FskRHHVs/nW8LFQHUJ2mPw6anHS+4HYoFwnlMkItf6KuStWU0J/8j7/60qaQSjsLrQL1Wal1IhSyoFeZnegtqqwmFJwMzADUqGBDYeVcyDAgD1uSmxHh+pX4p8Y7oGwD888n7NNKBKXmY7wjH/sfFyUjK2lz5cvxtBCFQxHI/WoZSmxRkxxGBE/O4xj+G5vwqSDnrfEu5C7PNsL/SfU4WC+p8rxwYB7ukiYOcTAjo0/NjcklxplWqhu6ux1yxcbwZ5uUM+Y2PozQetYXWXBQcM9aSytbE8L2J98UC+0bPOFE6Yz5j1QLpBq6QwKrAbW8mXdzmnbq0PhigKwaGgbc0Vl4Eg==
On 08/31/2015 07:21 AM, Cheng Zhao wrote:
Thank you very much Sebastien.
I tried already constructing the net using boundary facets with
Polyhedron_incremental_builder_3.
However, the problem is that it cannot handle the case shown in the
attached picture, where the edge indicated by the red arrow is shared by
4 faces. Hence there is the orientation problem:
lookup_halfedge(): input error: facet 39 shares a halfedge from vertex 6
to vertex 4 with facet 19.
Indeed Nef is able to handle non-manifold edges while Polyhedron_3 only handles manifold surfaces.
A solution (not sure it will be fast) is to write the boundary facets
in a stream using the OFF format and use the function
OFF_to_nef_3 (std::istream &i_st, Nef_3 &nef_union, bool verb=false)
that is defined in CGAL/OFF_to_nef_3.h
Sebastien.
I do not know how the union handles this case, but it seems that it
works (but unacceptably slow)...
2015-08-28 13:33 GMT+08:00 Sebastien Loriot (GeometryFactory)
<mailto:>>:
On 08/16/2015 12:16 PM, QYInst wrote:
I performed 3D Delaunay Triangulation on a point set.
Then I would like to select some of the joint cells (the overall
shape is
not a convex hull) and then decompose this set of cells to
convex hulls.
I successfully achieved it by constructing nef polyhedron from
the cells
(tetrahedrons) and then applying convex decomposition of polyhedra.
The problem is that the procedure of constructing polyhedron
from cells is
extremely slow given several hundred cells.
Basically below is my implementation:
1. For each of the cell in the joint cell set
(vector<Cell_handle> cell),
get the 4 vertices (vector<Point> P) and create a nef polyhedron
with them.
2. Get the union of the nef polyhedrons.
3. Decompose this nef polyhedron.
Below is the code for step 1 and 2.
for(size_t i = 0; i < cell.size(); ++i) {
for(int j = 0; j < 4; ++j)
P.push_back(cell[i]->vertex(j)->point();
Nef_polyhedron_3 NPtmp(P.begin(),P.end());
NP+=NPtmp;
P.clear();
This loop is very slow when cell.size() is about 200.
Is there any better way to achieve my goal, i.e. decompose a set
of cells to
convex hulls?
Any comments or suggestions will be highly appreciated.
I can see some speed up to avoid the union of nef polyhedra, by
directly constructing the final nef using the boundary facets of
selected cell.
Sebastien.
View this message in context:
http://cgal-discuss.949826.n4.nabble.com/construct-polyhedron-from-tetrahedrons-tp4661074.html
- Re: [cgal-discuss] construct polyhedron from tetrahedrons., Sebastien Loriot (GeometryFactory), 09/01/2015
