cgal-discuss - Re: [cgal-discuss] RGBD Field of View and mesh intersection surface (Occlusion culling)
  • To:
  • Subject: Re: [cgal-discuss] RGBD Field of View and mesh intersection surface (Occlusion culling)
  • Date: Tue, 01 Sep 2015 11:03:30 +0200
  • Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None ; spf=Pass ; spf=None
  • Ironport-phdr: 9a23:NpLZCRT7DdzIvtQA60NBFtWfZNpsv+yvbD5Q0YIujvd0So/mwa64YhCN2/xhgRfzUJnB7Loc0qyN4/umBjdLucnJmUtBWaIPfidNsd8RkQ0kDZzNImzAB9muURYHGt9fXkRu5XCxPBsdMs//Y1rPvi/6tmZKSV3BPAZ4bt74BpTVx5zukbvioNuMOE4Q23KUWvBbElaflU3prM4YgI9veO4a6yDihT92QdlQ3n5iPlmJnhzxtY+a9Z9n9DlM6bp6r5YTGfayQ6NtRrNRCHEqMns++dbwnRjFVwqGoHUGAUsMlR8dSTPI5hjhQpb8tGPesfB83zXSfeL7SrU5RS6zwa5gVBjymWZNf2oi9GbNi8tsyqdfiB2krh17hYXTZdfGZ7JFYqrBcIZCFiJ6VcFLWnkZDw==
Maybe using Side_of_triangle_mesh [1] (available in CGAL 4.7)
might help.
However, this won't give you face intersections nor edge intersections.
If you really need to refine the input mesh, there is some undocumented
code doing that.
Sebastien.
[1] http://doc.cgal.org/4.7/Polygon_mesh_processing/classCGAL_1_1Side__of__triangle__mesh.html
On 08/29/2015 10:30 PM, randa wrote:
I'm trying to get the intersection surface area between an RGBD sensor FOV
and a mesh model since I want to use these surfaces to fasten the
development of a reconstruction algorithm.
It is similar to the intersection surface of two models as it is shown in
the following image:
<http://cgal-discuss.949826.n4.nabble.com/file/n4661115/mxS4enXFjmWuyILduEG7SHjRQTUOOJDKC3-kbVTOGLc.jpeg>
, but instead of the sphere, I have the FOV (Quadrahedron shape) and instead
of the cube model, I have another model shape,
The blue part of the cube surface shown in the third part of the image is
the intersection surface needed to be found.
The result should be the visible surface in the Field of view similar to the
concept of occlusion culling
Is there a function in CGAL that can find this visible surface ?
Thanks
View this message in context:
http://cgal-discuss.949826.n4.nabble.com/RGBD-Field-of-View-and-mesh-intersection-surface-Occlusion-culling-tp4661115.html
  • Re: [cgal-discuss] RGBD Field of View and mesh intersection surface (Occlusion culling), Sebastien Loriot (GeometryFactory), 09/01/2015
