[cgal-discuss] Compiling "terrain.cpp" of the examples folder in CGAL 4.6 with OpenGL and GLUT in Mac (Yosemite 10.10.2)
- To:
- Subject: [cgal-discuss] Compiling "terrain.cpp" of the examples folder in CGAL 4.6 with OpenGL and GLUT in Mac (Yosemite 10.10.2)
- Date: Wed, 2 Sep 2015 00:39:15 +0530
- Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None ; spf=Pass ; spf=None
- Ironport-phdr: 9a23:0rmqgROvuXH0EVPRUbsl6mtUPXoX/o7sNwtQ0KIMzox0KP/4rarrMEGX3/hxlliBBdydsKIYzbKO+4nbGkU+or+5+EgYd5JNUxJXwe43pCcHRPC/NEvgMfTxZDY7FskRHHVs/nW8LFQHUJ2mPw6anHS+4HYoFwnlMkItf6KuStKU15z//tvx0qOQSj0AvCC6b7J2IUf+hiTqne5Sv7FfLL0swADCuHpCdrce72ppIVWOg0S0vZ/or9YwuxhX7vku/soFXaThdLkjVpRZCi4nOiY7/p7Frx7GGCKK739UfmgI2iIAVwHJ9FfnRp7quy3znuV40Siee8bxSOZnCnyZ8653RUqw2288PDkj/TSPhw==
Undefined symbols for architecture x86_64:
"_glBegin", referenced from:
drawFilledCircle(float, float, float) in terrain.cpp.o
pointset() in terrain.cpp.o
"_glClear", referenced from:
display() in terrain.cpp.o
"_glClearColor", referenced from:
_main in terrain.cpp.o
"_glColor3f", referenced from:
"_glEnd", referenced from:
"_glFlush", referenced from:
"_glLineWidth", referenced from:
"_glLoadIdentity", referenced from:
reshape(int, int) in terrain.cpp.o
"_glMatrixMode", referenced from:
"_glOrtho", referenced from:
"_glPointSize", referenced from:
"_glVertex2f", referenced from:
"_glViewport", referenced from:
"_glutCreateWindow", referenced from:
"_glutDestroyWindow", referenced from:
kbd(unsigned char, int, int) in terrain.cpp.o
"_glutDisplayFunc", referenced from:
"_glutInit", referenced from:
"_glutInitDisplayMode", referenced from:
"_glutInitWindowSize", referenced from:
"_glutKeyboardFunc", referenced from:
"_glutMainLoop", referenced from:
"_glutReshapeFunc", referenced from:
ld: symbol(s) not found for architecture x86_64
clang: error: linker command failed with exit code 1 (use -v to see invocation)
make[2]: *** [terrain] Error 1
make[1]: *** [CMakeFiles/terrain.dir/all] Error 2
make: *** [all] Error 2
Linking CXX executable Triangulation_2_example
make[2]: *** [Triangulation_2_example] Error 1
make[1]: *** [CMakeFiles/Triangulation_2_example.dir/all] Error 2
- [cgal-discuss] Compiling "terrain.cpp" of the examples folder in CGAL 4.6 with OpenGL and GLUT in Mac (Yosemite 10.10.2), Amal Dev P, 09/01/2015
