[cgal-discuss] Intersect lines with lines, and, polygons with polygons in 3D space
- To: <>
- Subject: [cgal-discuss] Intersect lines with lines, and, polygons with polygons in 3D space
- Date: Thu, 12 Nov 2015 18:38:39 +0100
- Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None ; spf=Pass ; spf=None
- Ironport-phdr: 9a23:vuvuRxymlgcC95DXCy+O+j09IxM/srCxBDY+r6Qd0ekUIJqq85mqBkHD//Il1AaPBtWGra4VwLuG+4nbGkU+or+5+EgYd5JNUxJXwe43pCcHRPC/NEvgMfTxZDY7FskRHHVs/nW8LFQHUJ2mPw6anHS+4HYoFwnlMkItf6KuStOU05X8hrD60qaQSjsLrQL1Wal1IhSyoFeZnegtqqwmFJwMzADUqGBDYeVcyDAgD1uSmxHh+pX4p8Y7oGwD884moppLXqz+Oqg5VrdFFy8OMmYv5cStuwOVHiWV4X5JUmILiQFFBUCR7BbnRYz8tAP7ruVlnieAa56lBYsoUCivuv84ACTjjz0KYmY0
Hello,
I need to intersect polygons, or lines, made of 3D points : is this possible with CGAL ?
I am new to CGAL.
First, I checked out the doc to intersect polygons, or lines, made of 2D points (x, y):
http://doc.cgal.org/latest/Sweep_line_2/index.html
http://doc.cgal.org/latest/Boolean_set_operations_2/index.html (in particular section 3.3)
I went accross the tutorials without any problem using Point_2, Segment_2 and Polygon_2.
Then, I looked at the doc related to using 3D points instead of 2D points (http://doc.cgal.org/latest/Polygon/index.html - section 2.3): it seems at least some operations are possible (for example, is_simple).
Now, I try to turn my basic tutorial into 3D space : basically, I tried to replace Point_2 by Point_3, Segment_2 by Segment_3, Polygon_2 by Polygon_3 the "naive" way, this seems not to be possible. CGAL::compute_subcurves turns out to be unable to support Segment_3, right ? Also Polygon_3 does not seem to exist ! :D
Can I compute intersections of polygons, or lines, made of 3D points (x, y, z) with CGAL ?
Franck
- [cgal-discuss] Intersect lines with lines, and, polygons with polygons in 3D space, houssen, 11/12/2015
- Re: [cgal-discuss] Intersect lines with lines, and, polygons with polygons in 3D space, zell_winston, 11/13/2015
- Re: [cgal-discuss] Intersect lines with lines, and, polygons with polygons in 3D space, Sebastien Loriot (GeometryFactory), 11/13/2015
