Re: [cgal-discuss] Intersect lines with lines, and, polygons with polygons in 3D space
- To: <>
- Subject: Re: [cgal-discuss] Intersect lines with lines, and, polygons with polygons in 3D space
- Date: Fri, 13 Nov 2015 11:45:49 +0100
- Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None ; spf=Pass ; spf=None
- Ironport-phdr: 9a23:UhvrbhSSo+04UyC/ufhNMVcMMdpsv+yvbD5Q0YIujvd0So/mwa64ZxaN2/xhgRfzUJnB7Loc0qyN4/2mBDVLuMvJmUtBWaIPfidNsd8RkQ0kDZzNImzAB9muURYHGt9fXkRu5XCxPBsdMs//Y1rPvi/6tmZKSV3BPAZ4bt74BpTVx5zukbviptuOOk4R2XKUWvBbElaflU3prM4YgI9veO4a6yDihT92QdlQ3n5iPlmJnhzxtY+a9Z9n9DlM6bp6r5YTGfayQ6NtGbdXBTBjP2Eu79DwrjHCSxGO7z0SSDNFvABPBl3F6wzhRZr3+n/6sfdmwyScFczuQqhyVy70vPQjcwPhlCpSb21xy2rQkMEl1K8=
They are general 3D primitives (polygons may not be planar).
Thanks, I'll take a look at the Intersecting Sequences of dD Iso-oriented Boxes package.
Franck
Le 2015-11-13 8:54, Sebastien Loriot (GeometryFactory) a écrit :
It is not clear if your primitives lies in a common plane or if they
are general 3D primitives.
If they are general 3D primitives, you should triangulate you polygons
first and then use the Intersecting Sequences of dD Iso-oriented Boxes
package [1].
Sebastien.
[1] http://doc.cgal.org/latest/Box_intersection_d/index.html
On 11/12/2015 06:38 PM, houssen wrote:
Hello,
I need to intersect polygons, or lines, made of 3D points : is this
possible with CGAL ?
I am new to CGAL.
First, I checked out the doc to intersect polygons, or lines, made of 2D
points (x, y):
http://doc.cgal.org/latest/Sweep_line_2/index.html
http://doc.cgal.org/latest/Boolean_set_operations_2/index.html (in
particular section 3.3)
I went accross the tutorials without any problem using Point_2,
Segment_2 and Polygon_2.
Then, I looked at the doc related to using 3D points instead of 2D
points (http://doc.cgal.org/latest/Polygon/index.html - section 2.3): it
seems at least some operations are possible (for example, is_simple).
Now, I try to turn my basic tutorial into 3D space : basically, I tried
to replace Point_2 by Point_3, Segment_2 by Segment_3, Polygon_2 by
Polygon_3 the "naive" way, this seems not to be possible.
CGAL::compute_subcurves turns out to be unable to support Segment_3,
right ? Also Polygon_3 does not seem to exist ! :D
Can I compute intersections of polygons, or lines, made of 3D points (x,
y, z) with CGAL ?
Franck
- [cgal-discuss] Intersect lines with lines, and, polygons with polygons in 3D space, houssen, 11/12/2015
- Re: [cgal-discuss] Intersect lines with lines, and, polygons with polygons in 3D space, zell_winston, 11/13/2015
- Re: [cgal-discuss] Intersect lines with lines, and, polygons with polygons in 3D space, Sebastien Loriot (GeometryFactory), 11/13/2015
- Re: [cgal-discuss] Intersect lines with lines, and, polygons with polygons in 3D space, houssen, 11/13/2015
